Proving Subspace Membership in R^2 using Vector Dot Product
10 replies · 4K views · last reply
frasifrasi
The question I am looking at asks,
Let a be the vector (-1,2) in R^2. Is the set S = { x is in R^2 | x dot a = 0}
a subspace?
--> x and a are vectors...
Can anyone explain how to show this?
I was thinking that since the zero vector is in R^2, this must also be a subspace.
Thank you.
Since 0 is in S, you can't conclude that S that S is not a subspace.
Is it a subspace? To aswer this, you must show that S is closed under addition and scalar multiplication. It is pretty direct, try it.
If you run into problem, I can help you.
Oh yes.
Ok, but how would I proceed.
Do i just look at 0 -- k(0) = (k0).
I am not sure how to apply the axiums, can you/someone demonstrate?
Thank you.
I'll do closure under addition for you.
Let x and y be in S. We want to show that x+y is in S also.
well (x+y) dot a = (x dot a) + (y dot a) = 0 + 0 = 0,
so x+y is in S!
(I used the distributivity property of the scalar product)
For the constant,
k(x dot a) = (kx dot a)
k(0) = 0
0 = 0
Is this the proper way?
Thanks for the help.
The exposition is not very logical.
Try again using my template.
"Let x be in S and k be a constant. We want to show..."
Why do you keep looking at 0? Not only does just proving that 0 is in the set not prove it is a subspace, you don't need to prove that 0 is in the set!
You need to prove two things: the set is closed under addition and the set is closed under scalar multiplication.
Suppose u and v are two vectors such that [itex]u\cdot a= 0[/itex] and [itex]v\cdot a= 0[/itex] where a is a fixed vector. Can you prove that u+ v is also in that set- that [itex](u+v)\cdot a= 0[/itex]?
Suppose u is a vector such that [itex]u\cdot a= 0[/tex] and [itex]\alpha[/itex] is any real number. Can you prove that [itex]\alpha[/itex] is also in that set- that [itex]\alpha u\cdot a= 0[/itex]?<br /> <br /> After you have proved the second of those, you don't need to prove 0 is in the set- it follows from the fact that 0v= 0 for any v.[/itex]
so, au dot a = 0
u dot a = 0
so, u(0) = 0.
Is that enough?
thank you for the patience everyone.
frasifrasi said:
so, au dot a = 0
u dot a = 0
so, u(0) = 0.
Is that enough?
I have no idea what you mean by this. You started with a a vector so I don't know what you mean by "au dot a= 0". Did you accidently also use a to mean a number?
What do you mean by u(0)? u is a vector, not a function.
If I try to translate, I get "If ku dot a= 0, then u dot a= 0".
That's exactly the opposite of what I suggested: Show that if u dot a= 0, then ku dot a= 0 for any real number k.
And, of course, you must prove that if u dot a= 0 and u dot v= 0, then (u+ v) dot a= 0.
like the poster above mentioned,
(u+v) dot a = 0
then
(u dot a) + (v dot a) = 0
0 + 0 = 0 so, that is closed under addition.
For scalar multiplication, yes I meant k:
k(u dot a) = k.0 = 0
ku dot a = k.0 = 0
Is this the right way to prove it?
Maybe you understand, but I wouldn't know because your exposition lacks words or at least "<==>" symbols for it to make any sense.
In your proof of scalar multiplication, the critical part of the proof is the fact that ku dot a = k(u dot a). I see you nowhere make that connection explicitely.
