Proving that lcm(a,b)gcd(a,b)=ab
  • Thread starter Thread starter Mr Davis 97
8 replies · 5K views
Mr Davis 97
Let ##a\neq 0, b\neq 0## be integers and let ##(a),(b)## be the ideals they generate in ##\mathbb{Z}##. Show that ##\operatorname{gcd}(a,b)\operatorname{lcm}(a,b) =ab##
Suppose that I already know from the second isomorphism theorem that
$$\frac{(a)}{(\gcd(a,b))} \cong \frac{(\rm{lcm}(a,b))}{(b)}.$$ How can I get from this the result ##\operatorname{gcd}(a,b)\operatorname{lcm}(a,b) =ab##?
There's no need to use isomorphism theorems. Basic set theory will suffice.
Let the prime factors of ##ab## be ##p_1,...,p_n## and let ##a=\prod_{k=1}^n p_k{}^{r_k}## and ##b=\prod_{k=1}^n p_k{}^{s_k}##.
Now write each of gcd(##a,b##), lcm(##a,b##) and ##ab## in that prime-factorised product form (you'll need to use min and max functions). It should be easy to prove the required identity from there, given that ##p^{\min(\alpha,\beta)}p^{\max(\alpha,\beta)} = p^{\alpha+\beta}##.
... but I sounds as an elegant idea.
Mr Davis 97 said:
Suppose that I already know from the second isomorphism theorem ...
Consideration of ##\mathbb{Z}_a\; , \;\mathbb{Z}_b\; , \;\mathbb{Z}_a + \mathbb{Z}_b\; , \;\mathbb{Z}_a \cap \mathbb{Z}_b## should do.
How can I consider these rings such as ##\mathbb{Z}_a## and ##\mathbb{Z}_b## if they are not principal ideals of ##\mathbb{Z}##, which they must be by hypothesis?
Mr Davis 97 said:
How can I consider these rings such as ##\mathbb{Z}_a## and ##\mathbb{Z }_b## if they are not principal ideals of ##\mathbb{Z}##, which they must be by hypothesis?
Sorry, my fault. I meant ##a\mathbb{Z}\; , \;b\mathbb{Z}\; , \;(a+b)\mathbb{Z}## or ##(ab)\mathbb{Z}## and ##a\mathbb{Z} \cap b\mathbb{Z}## of course, the ideals, not the quotients.
I'm not seeing how consideration of these implies the result though
fresh_42 said:
Yes, you completely confused me, as we need the quotients for the finite number of elements to represent the formula.
... guess, I should do it first on my own ...
I think maybe we just look at subgroup indices
I must admit, that I haven't found a nice way, although I still think there is one. But my attempts all ended up in diagram chasing. To use isomorphism theorems, one probably needs to show that ##(a\mathbb{Z}\cap b\mathbb{Z})/ ab\mathbb{Z} \cong \mathbb{Z}/(a\mathbb{Z}+b\mathbb{Z})##. Maybe you have an idea how to show that fast. I even tried to use the four, five and nine lemmas.
