Proving the Distributive Property for Rings
  • Thread starter Thread starter ArcanaNoir
    Rings
10 replies · 3K views
ArcanaNoir
I need to show that (-x)*y=-(x*y) for a ring. unless it's not true.
A ring is a set R and operations +, * such that (R, +) is an Abelian group, * is associative, and a*(b+c)=a*b+a*c and (b+c)*a=b*a+c*a.
I don't know what the first step of this proof will be, I'm looking for the *trick*, as it were.
I don't know. maybe if I knew what axiom to check I'd have a better idea how to prove it?
-(a+b)= (-b)+(-a)
right?
That not a definition, is it? I was under the impression that "-x" was the additive inverse of x: x+ (-x)= 0. So to prove that (-x)y= -(xy), you need to show that (-x)y is the additive inverse of xy: that (-x)y+ (xy)= 0.
Let's try to find the definition of a ring, and in particular the definition of the additive inverse.
On wikipedia there is an article on a ring.
It lists the requirements (aka axioms) of a ring:
http://en.wikipedia.org/wiki/Ring_math#Formal_definition
In particular we have:
wiki on Ring said:
4. Existence of additive inverse. For each a in R, there exists an element b in R such that a + b = b + a = 0
Btw, the typical shorthand for the additive inverse of [itex]a[/itex] is [itex]-a[/itex].
Does this look familiar?
(-x)y+xy=((-x)+x)y=0y=0
ta da?
well I did check that 0y=0, and a+b should equal b+a because its an abelian group. yay :) thanks again!
You're making this a bit easy on yourself, aren't you?
How did you check this?
If it is so simple, you should be able to easily reproduce the proof...
(It is not trivial!)
Yep!
