Proving the limit of an integral function
10 replies · 2K views
armolinasf
Show that the Lim x=> inf. R(x)/x^2 exists and find its value.
R(x)= [tex]\int^{x}_{0}[/tex] [tex]\sqrt{1+t^{2}}[/tex]
I know that the limit is 1/2 however i got that by just evaluating at large values of x. How would I go about solving this analytically? Thanks for the help
Use L'Hospital's rule remembering how to differentiate an integral as a function of its upper limit.
how about starting by attempting the indifinite integral, then applying the limit
much better idea, once you know the intergal is unbounded in the limit
Let me know if this works: applying L'H I get x/(1+x^2) * 1/2 if I set x equal to infinity wouldn't that give me inf/inf=1*1/2 which would give me the correct limit?
That's not very clear. What do you get from l'Hopital? Shouldn't there be sqrt in there somewhere?
you're right, my mistake.
taking derivatives I get sqrt(1+x^2)/2x. So, can't I factor out 1/2 leaving me with sqrt(1+x^2)/x * 1/2. If I take the limit it should be infinity/infinity times 1/2 which is the same 1*1/2?
Don't EVER say infinity/infinity=1. That's the whole point of l'Hopital. infinity/infinity can be anything. Can't you prove the limit of sqrt(1+x^2)/x is 1 without saying that?
sqrt(1+x^2)/x is indeterminate when x=inf. So if I were apply l'Hopital again I get into this repeating pattern where I wind up at the same thing. For example, applying L'H to sqrt(1+x^2)/x gives x sqrt(1+x^2)/x and I'm back where I started.
By the way, the actual equation is sqrt(1+x^2)/2x I'm wondering if it's possible to factor out a 1/2 and then apply L'H after that? Or would that change the expression?
Don't apply l'Hopital. (1/x)*sqrt(1+x^2)=sqrt((1/x^2)*(1+x^2)). l'Hopital isn't always the best way to do it. But sure you can factor out the 1/2.
If I were to go at it without l'Hopital I would try to factor the numerator and the denominator and cancel out one of the x's but I'm not really seeing a way to factor sqrt(1+x^2)/x^2
