Proving |x + y| ≥ |x| - |y| using Theorem 3 and the fact that |-y| = |y|
  • Thread starter Thread starter jimmyly
    Inequality
The discussion centers on proving the inequality |x + y| ≥ |x| - |y| using Theorem 3, which states that |a + b| ≤ |a| + |b|. Participants explore the application of the theorem by rewriting x as x + y - y and utilizing the property |-y| = |y|. The conversation reveals confusion regarding the manipulation of absolute values and the correct application of the theorem, ultimately leading to a consensus that the proof is direct and valid.
  • Understanding of absolute value properties
  • Familiarity with Theorem 3: |a + b| ≤ |a| + |b|
  • Basic algebraic manipulation skills
  • Knowledge of direct proof techniques in mathematics
  • Study the properties of absolute values in depth
  • Practice applying Theorem 3 in various mathematical proofs
  • Learn about direct and indirect proof methods
  • Explore examples of inequalities involving absolute values
Students learning mathematical proofs, particularly those studying inequalities and absolute values, as well as educators seeking to clarify proof techniques in a classroom setting.
jimmyly
|x + y| ≥ |x| - |y| [Hint: write out x = x + y - y, and apply Theorem 3, together with the fact that |-y| = |y|]
x = x + y - y
|-y| = |y|
|x + y| ≥ |x| - |y|
x = x + y - y (don't know where to use it)
xy ≤ |xy| = |x| |y| ( I really don't know why I am taking these steps, I am pretty much following the proof of theorem 3 in this book)
2xy ≤ 2|x||y| ( does the |-y| = |y| come into play here to flip the inequality? )
(x+y)^2 = x^2 + 2xy + y^2 ≤ x^2 - 2|x||y| + y^2 = (|x| - |y|)^2
x = x + y - y
|-y| = |y|
|x + y| ≥ |x| - |y|
x = x + y - y (not sure why this is true, and don't know where to use it)
Is it not obvious that x + y - y = x + (y - y) = x + 0 = x?
hi jimmyly! :smile:
jimmyly said:
x = x + y - y (not sure why this is true …
add some brackets …
x = x + (y - y)
now can you see why it's true? :wink:
… and don't know where to use it)
add some brackets in a different place :wink:
hi jimmyly! :smile:
jimmyly said:
… I just don't know what that has to do with proving it.
y - y = 0
x + (y - y) = x + 0
x + 0 = x ? o:)
@mark-44: How was it false? I mean if you could clarify that would be great. Wasn't trying to spread false information or anything.
Tornado Dragon said:
You have to remember that |x|= x so for |-x| it becomes -(-x)= + x.
So When you change || to how you normally write it out you get: x + y>= x + y Which can then be written as:
I don't understand why I would write x + y ≥ x + y
how does the subtraction turn into addition? does this mean that x + y = |x| - |y|? I see that -(-x) = + x
but its |x| - |y| not |x| + |-y|
or is my thinking wrong?
tiny-tim said:
hi jimmyly! :smile:
y - y = 0
x + (y - y) = x + 0
x + 0 = x ? o:)
Thank you, I understand why x = x + y - y it is very obvious! I am confused because I have no idea what it has to do with the proof and where to apply it when proving that |x+y| >= |x| - |y|
Tornado Dragon's post was full of errors, so I deleted it. Right at the start he tells you to remember that |x|= x. This is not true in general, particularly if x happens to be negative.
No, it's not. You can't just ignore the absolute value signs, which Tornado Dragon seems to have done.
apply Theorem 3 to x = x + y - y (with brackets in a suitable place) :wink:
@jimmyly ignore my post I have made a few mistakes in it. I will get back to you on it once I have gone it over it again.
edit: @mark44&jimmlyl: I did make en eroneous error but I did not ignore the absolute signs like that I will redo it and post it at a later tim.e.
okay so here is what I'm doing right now
|x+y| >= |x| - |y|
with x = x + y - y
I got
|x + y| >= |x| + |y| - |y| - |y|
cancelling the |y|
|x + y| >= |x| + |y|
am I on the right track? :)
understandable
no worries we all make mistakes!
Take your theorem 3, |a+b|<=|a|+|b|. Put a=x+y and b=(-y). What happens?
no!
Theorem 3 applies to 3 things
use brackets to reduce the number of things to 3 !
then you can apply Theorem 3 :smile:
so from this I got
|a + b| <= |a| + |b|
|(x+y) + (-y)| <= |x+y| + |-y|
|x + y - y| <= |x+y| + |-y|
|x| - |y| <= |x + y|
oh that just did it didn't it?!
Sure did!
Would this be classified as a direct proof? I'm trying to learn proofs on my own so this is a little bit confusing to me. Thanks everyone for helping me out!
Dick said:
Sure did!
Wow that's amazing. Thanks everyone! You are all wonderful
jimmyly said:
Would this be classified as a direct proof? I'm trying to learn proofs on my own …
jimmyly, you seem to be worrying that there's something special about proofs
there isn't
if it starts with the question and finishes with the answer, it's a proof! :smile:
Yes, it's a direct proof. Indirect proofs work by assuming what you are trying to prove is false. Then you show that leads to a logical contradiction. So what you are trying to prove must be true. Also called "proof by contradiction".
there isn't
Thank you! :)
  • · Replies 17 ·
11K
  • · Replies 19 ·
  • · Replies 19 ·
