Proving Vector Bisector Theorem: Simplifying Dot Products
  • Thread starter Thread starter Jake 7174
    Angle Vectors
14 replies · 3K views
Jake 7174
Show that vector C = (BA + AB) / (A + B) is an angle bisector of A and B. Where vectors are represented by bold font, and magnitudes are regular font.
A ⋅ C = A C cos(θ) ⇒ cos(θ) = (A ⋅ C) / (A C)
B ⋅ C = B C cos(θ) ⇒ cos(θ) = (B ⋅ C) / (B C)
We know that if C is a bisector of A and B, then ∠AC =∠BC = θ must be true.
I set the above equations equal to each other to get;
(A ⋅ C) / (A C) = (B ⋅ C) / (B C)
I notice the magnitude C cancels and then cross multiply the expression to get;
(A ⋅ C)B = (B ⋅ C)A
I bring the right side over and use identities of dot products to get;
C ⋅ [BA - AB] = 0
This is where I am stuck I don't know how to take it any further. I would appreciate a push in the right direction.
Hello Jake, :welcome:
Fill in something for C to proceed !
(for example (BA + AB) / (A + B) :smile: )
Hi BvU,
Thanks for responding.
I don't understand though. How can I fill in something for C. C is some vector C(x,y,z) that bisects A and B. If I simply substitute the solution for C into C, then I will not have proved the expression in the problem statement. I have to prove the relationship is valid.
The problem is NOT to prove "the expression in the problem statement". That is given. The problem is to prove that the two angles are equal using that expression.
So, how do I do that given what has been done above? What was suggested was to sub in the expression for C. What then? Do i simplify and see if it goes to zero?
Please excuse any bad spelling. I am on a phone walking thru campus.
You work it out and see that it IS zero.
So why didnt you just say that in the first place? Oh wait you did. I hope the humor in that statement was not lost in text. Thank you very much for taking your time to help me. I truly apreciate it.
You're fine and I'm fine too. No worry !
I worked it out using my calculator. It is not zero. Did I do something wrong in my earlier steps? If I did I do not see it.
Please, can someone help. This is due on Monday. I have spent hours on this and am stuck.
Seriously need help. Due tomorow. I have been going round and round in circles and can't get it.
Just do what @BvU has been saying all along:
compute C ⋅ [BA - AB] by using the given value of C:
C
You don't need a calculator for that.
When i make the substitution and carry out the dot product the result is as follows;
1/(A + B) [ B^2Ax^2 - A^2Bx^2 + B^2Ay^2 - A^2By^2 + B^2Az^2 - A^2Bz^2 ]
This is not zero. I used my calculator to verify my work and i got the same result.
I don't have a clue how you get that result.
Let's forget the denominator (A+B) for the moment.
Just focus on X = (BA + AB)⋅(BA - AB).
The dot product is distributive over addition, so X = B²A⋅A-BAA⋅B+ABB⋅A-A²B⋅B
Can you further simplify this, using the properties of the dot product (it is commutative, Y⋅Y=Y², ...)?
Your the man samy. I see it. I did not know Y⋅Y=Y². Clearly i need more work on this. Thank you so much. You really helped me out here.
