Proving Vector Norm Properties Using Different Definitions
14 replies · 4K views
mathnerd15
this is an Apostol problem in chapter 12 and I guess it's a hypothetical definition of a norm of a vector
Assuming this different definition of the norm prove these statements-
[tex]Def. ||A||=\sum_{k=1}^{n}|a_{k}|, prove ||A||>0, if ||A||\neq0,||A||=0 if A=0, ||cA||=c||A||,triangle equality ||A+B||\leq ||A||+||B||,[/tex]
I just looked at this- do I just expand the sums out and then express them in sigma notation?
Use this definition in V2 and prove on a figure the set of all points (x,y) of norm 1- this is just the line x+y=1?
which of the above theorems/statements would hold if we take the absolute value of the summation?
[tex]Def. ||A||=|\sum_{k=1}^{n}a_{k}|[/tex]
Assuming this definition of the norm prove these statements-
[tex]Def. ||A||=\sum_{k=1}^{n}a_{k}\text{, prove }||A||>0\text{, if }||A||\neq0,[/tex]
You haven't told us what ##A## is or what the ##a_k## are. If ##n = 2## is ##v = \langle 1,-1\rangle \in A##? If so ##v \ne 0## but ##\|v\| = 0##.
Mostly I'm asking about the triangle inequality proof, the problem just gives you a general vector A
I think the hypothetical definition is ||A||=|a1|+|a2|+|a3|...+|an|, so if ||A|| norm doesn't equal the zero vector (0,0...0) and at least one component |ak|>0, then the sum must be >0
You "think" that is the norm definition? It's your question -- is it or isn't it? I see you edited your post to change it to that. And given your last sentence, what is your question?
[Edit] Re the triangle inequality, what have you tried?
I'm just trying the TE for the first time. Apostol gives this 'incorrect' definition of the norm and asks you to prove the TE. I proved the law of cosines in norm form. here I see it is correct for a case where the signs of A and B are different
[tex]Def. ||A||=\sum_{k=1}^{n}|a_{k}|, triangle.inequality ||A+B||\leq ||A||+||B||. e.g.A=-2,B=1,|-1|\leq 3[/tex]
What do you mean the signs of A and B? That doesn't make any sense. They are vectors, not scalars. You have to start by calculating A+B and its norm and compare it with the norms of A and B.
I've attached the written problems, is this how I prove the triangle equality for this definition of norm, I ended up with something that seems analogous to Cauchy-Schwarz inequality?
anyways I started to lose confidence after thinking my handwriting was too messy after I saw a video of Andrew Wiles
You are making it way too hard. Like I said before, calculate A+B and its norm. You don't need to square anything. Just use a familiar inequality. Show your work here, not in a pdf.
[tex]||A+B||\leqslant ||A||+||B||\rightarrow \sum_{k=1}^{n}|ak+bk|\leq \sum_{k=1}^{n}|ak|+\sum_{k=1}^n|bk|[/tex]
so this is trivially true by properties of absolute value? there are many more beautiful properties of absolute value functions
the last part of the solution is
|x|+|y|=1 and y=1-x, y=x+1, y=x-1, y=-x-1, and since |x|+|y|=1, then these lines become segments, 0<=x<=1 constrained and form a rectangle in V2 (similar to R2?)
mathnerd15 said:
[tex]||A||+||B||\leqslant ||A+B||\rightarrow \sum_{k=1}^{n}|ak|+ \sum_{k=1}^{n}|bk|\leq \sum_{k=1}^{n}|ak+bk|[/tex]
No, that is so wrong it leaves me speechless. One more time I will ask you:
1. Write down A = ... and B = ... and then what is A + B is.
2. Then write down its norm ##\|A+B\| =##?
Then you are ready to try to get the inequality.
Sorry I'm not sure what you mean, the text gives you a hypothetical definition of norm as the sum of absolute values of |ak|
the true definition of norm as dot product gives a proof of the triangle equality from algebra or as a consequence of the Cauchy-Schwarz inequality
Sorry, but I will not download a pdf file for a simple problem like this. You can easily type it. But until you do 1. and 2. above, I don't see where we have anything to discuss.
The Cauchy-Schwarz inequality has nothing to do with this problem.
[Edit] I now see you have changed post #9 to make it correct, without noting that it was changed. That makes it very difficult to maintain continuity of the thread and is against forum rules.
[tex]A=\sum_{k=1}^{n}akEk, B=\sum_{k=1}^{n}bkEk, ||A||=\sqrt{A\cdot A}. <br /> \\ ||A+B||=\sum_{k=1}^{n}[(ak+bk)^{2}]^{1/2}, <br /> \\ but here ||A||=\sum_{k=1}^{n}|ak|, ||B||=\sum_{k=1}^{n}|bk|, <br /> \\ ||A||+||B||=\sum_{k=1}^{n}(|ak|+|bk|), ||A+B||=\sum_{k=1}^{n}\|ak+bk|<br /> \\ \sum_{k=1}^{n}\|ak+bk| <=\sum_{k=1}^{n}(|ak|+|bk|)[/tex]
I'm sorry, so all vectors in Vn can be expressed as linear combinations of the orthogonal basis vectors [Ek,En] or other arbitrarily rotated orthogonal basis vectors as well as the imaginary basis vector on the C plane? I've written what I think is the definition of norm/length and also the hypothetical one (I'm not sure if there's some significance to Apostol's hypothetical problem)
actually since ||A|| is defined as the sum of absolute values then if v=(1,-1) then ||v||=2, not 0, while normally
[tex]||v||=2^{1/2}[/tex]
it is really the greatest achievement of humanity! by the way what would be an example of a difficult proof to try that is more advanced or a text?
