Is the Water Pressure Inside a Cup Equal to 14.7 psi Due to Atmospheric Force?
  • Thread starter Thread starter Idea04
    Psi Water
The atmospheric pressure of 14.7 psi is not directly transferred to the water inside an upside-down cup due to the influence of the water column's height and density. The pressure at the top of the water column in the cup will not equal 14.7 psi; instead, it will be influenced by the weight of the water column above it. The pressure at the bottom of the column can be calculated using the formula P = rho*g*h, where rho is the density of the fluid, g is gravity, and h is the height of the water column. The pressure at the top of the column will be significantly lower than atmospheric pressure, especially in smaller containers.
  • Understanding of fluid dynamics principles
  • Familiarity with pressure measurement units (psi, mmHg)
  • Knowledge of Bernoulli's equation
  • Basic grasp of hydrostatic pressure calculations
  • Study hydrostatic pressure calculations using P = rho*g*h
  • Learn about Bernoulli's equation and its applications in fluid dynamics
  • Explore the relationship between atmospheric pressure and fluid columns
  • Investigate the effects of fluid density on pressure in different scenarios
Students in physics or engineering, educators teaching fluid dynamics, and anyone interested in understanding the principles of pressure in fluids.
Idea04
If you take a cup of water upside down on top of water in a bowl. The water doesn't flow out because of atmospheric force. So my question is, is the atmospheric pressure of 14.7psi transferred to the water in the cup. So is the water pressure inside the cup then 14.7 psi?
if the pressure inside the cup was not equal to the atmospheric pressure, what would happen?
So water open to the air will always have a pressure of 14.7psi. plus its own pressure.
So if the atmospheric pressure is transferred to the water, If you take a column of water 12 feet vertical with the top closed off and water entering at the bottom, with no air inside the column the water would rise to even pressure. So my question is would the atmospheric pressure be transferred throughout the water in the column. So at the top of the column would the pressure be 14.7 psi?
well, think about the units for stating a pressure as a height of a fluid
mmHg (milimeters of mercury)
760 mmHg = 14.7psithat is, a column of mercury 760mm high will exert a pressure at the bottom, equal to atmospheric pressurenote that mercury is much denser than water and the water column that would provide a pressure of 14.7 psi would actually be 13.6 times taller
(because the density of water is 13.6 times that of mercury)the pressure at the bottom of a column of liquid is due to its weight
it can be calculated from:
P = rho*g*h
rho being the density of the fluid, g being gravity, and h being the height of the column
err
at the top of the column...
no
the pressure that the column of water exerts is the weight of all the fluid
so at the top of the column it's just vapor pressure which is negligibly small
hmm...let me think about it a little more
i think it depends on the size of the glass
a small glass would not have a water column that would provide enough pressure to balance with the atmospheric pressure, so it seems that the pressure at the top would be the pressure needed to reach atmospheric after taking into account the pressure provided from the small column of wateralternatively...a glass that's 15 m tall, would be able to balance atmospheric pressure with the height of the water column it can provide, so the pressure at the top of the glass would basically be 0
okay, But having a column of water closed off at the top so no air can push downward is different then water sitting in a open top container.
The pressure of the atmosphere pushes the water up into the column. Keeping in mind that there is no air inside the column. So if the column was filled to the top it would exert around 5 psi downward pressure. That would be less than atmospheric pressure.
So my way of thinking, the pressure would be 14.7 psi in the column.
But would that be transferred to all parts of the column, or would the top of the column be 9.7psi and the bottom be 14.7 psi?
if the glass was full, and the water in the bowl is trying to force its way in with atmospheric pressure
then the pressure at the top of the glass is the difference in pressure between atmospheric and the pressure provided by the water column inside the glass
I suppose you could consider the water column to provide negligible pressure and say that the pressure at the top of the glass is atmospheric pressure
it wouldn't be the exact answer, but a water column in a normal sized glass wouldn't provide very much pressure at all
the main thing, is that the pressure where the glass meets the free surface has to be atmospheric pressure
it'll be a constant at any point in that elevation
looking at the surface of the water in the bowl, it has atmospheric pressure at that elevation because that is what is causing the pressure at that point (the weight of the air column above it)
looking at the water at the bottom of the glass at the same elevation as the surface of the water in the bowl, it has atmospheric pressure at this elevation but it is not due to the column of air above it, it is due to the weight of the column of water above it and the pressure inside the glass
since no size of glass was given, it would not be wise to assume the pressure provided by the column of water is negligible
therefore,
the pressure at the top of the glass is the difference in pressure between atmospheric and the pressure provided by the column of wateryou can apply bernoulli's equation to the top of the glass and the free surface in order to reach this conclusion as well
9K
