Pulling down on the string connected to a whirling block on a table
1 reply · 3K views · last reply
farfromdaijoubu
A horizontal frictionless table has a small hole in its centre. Block A on the table is connected to block B hanging beneath by a massless string which passes through the hole. Initially, B is held stationary and A rotates at constant radius R with constant angular velocity \omega If B is released at t=0, what is its acceleration immediately afterward?
[tex]T-m_ag = m_aa[/tex]
[tex]T=m_b\omega^2R[/tex]
At the time of release, the equation of motion of blocks A and B [tex]T-m_ag = m_aa[/tex] and [tex]T=m_b\omega^2R[/tex] respectively, where T is the tension in the string. Solving for the acceleration a then gives [tex]a=\frac{m_b\omega^2R - m_ag}{m_a}[/tex]. Not sure what I did wrong or what incorrect assumptions I made here...
Thanks
Diagram of a block A whirling in a horizontal circle of radius R on a table, connected by a string through a hole to a hanging block B below, with the vertical distance labeled z.
Welcome to PF!
farfromdaijoubu said:
Relevant Equations:: [tex]T-m_ag = m_aa[/tex]
Block ##A## is the block that is initially moving in a circle. Block ##B## is the hanging block. It looks like your subscripts ##a## and ##b## should be switched if ##a## is meant to refer to block ##A## and ##b## to block ##B##.
A couple of things to consider:
(1) When block ##B## is released, the tension ##T## will "instantaneously" change from what it was just before ##B## was released. Just before ##B## is released, the tension is ##m_a \omega^2 R## because ##A## is moving in uniform circular motion before ##B## is released. But this will generally not be the tension just after ##B## is released.
(2) Block ##A## moves on a plane where polar coordinates would be appropriate for this problem. You might want to review how acceleration is expressed in polar coordinates. For example, see equation 4 here.
