Pulling yourself up with a pulley
  • Thread starter brycenrg
    Pulley
9 replies · 10K views · last reply
brycenrg
A window washer pulls herself up using a bucket that she stands in and a pully system that she pulls down on a cord to go up.
How hard must she pull in order to go up slowly at a constant speed?
assuming pulley frictionless and massless
f=ma
I set up a FBD but apparently it was wrong and i don't fully understand why.
I set it up as the bucket+human = T - mg = ma
and the other side of the pull the cord which is Fh - T = ma
Fh = Force by hand
In the book they just say its 2T - mg = ma which I get my Fh is = to T but I don't see how the pulley makes it 2T. It does make some sense as it is easier to pull down then pull up but.. i can't wrap my head around it lol any help?
There is tension in both ropes and there is a force from the other rope on the bucket (and a force from the bucket on the cleaner).
It is asking us to find the amount of force applied Fa in one end in order to pull up the human in the bucket 'slowly' at constant speed. It basically is asking for the amount of force required for there to be no net force.
Let's first indicate positive directions as upward, for the end where the human is in the bucket, and downward for the end where the rope is being pulled.
The tension in one end is the same as the tension in the other. The acceleration is also the same for both ends.These are property of this type of system (known as atwood's machine).
Account for the forces acting on each ends and list them out.
Fnet = T - mg = ma = 0
Fnet = FA - T = ma = 0
Now use your knowledge in what these quantities mean and you can re-write this in the way your book wants you to.
I get that, but my book wants it to look like 2T = mg how do I get that by getting rid of Fh
I thought they were asking you to find the applied force? In any case, the tension is not equal to half of the force of gravity of one side.
If you derive tension from the equations above, the tension is equal to mg. Not only that, but force applied is as well. They want you to equalize the force of gravity of an object with an equal force on the opposite end.
The tension is equal and opposite in both ends to the force downward. If it were not the case, and instead 2T = mg, then both ends would accelerate downward which is impossible.
Edit: here this should help http://www.drcruzan.com/AtwoodsMachine.html
I am asking for her applied force. According to my book you are wrong. It shows an FBD of mg the girl in the bucket pointing down and two forces of T pointing up.
It says you only show the forces acting on the bucket holding the girl. So because she pulls down her Force is = T so on both sides T points up. Lol doesn't really make sense but thanks anyways.
  • Textbook page showing problem 32 on a window washer's rope and pulley setup, with a small free-body diagram of the bucket-washer combination showing upward forces and weight mg, and problem 33 with free-body diagrams of two buckets.
    Screenshot from 2016-02-23 21:26:04.png
I suggest you make a free body diagram of a system which includes the girl and the bucket and the rope up to some height above the girl.
What forces are acting on this system?
What is then the tension in the rope?
Once you have that answered you can start asking yourself what the pulling force is.
I made an FBD and I know their are only 4 forces because string is massless and pulley is frictionless. But I just don't get how the force she pulls down only has to be half her weight.
I guess when pulling on a system like that you only consider your tension force on the one side because that is the reaction force to your pulling and there is actually no mass there. hmm makes sense i think
Sorry, I did not consider treating the pulley system as a whole. The human is directly affected through Newton's third law by both ropes. This system can be thought of as one mass held together by two strings. In that case, T = 1/2 mg. Because the forces on the system is
Fnet = 2T - mg = ma = 0
On individual ends the net force can be written
Fnet = T - Fa = ma = 0
And
Fnet = T - mg =ma = 0.
There is one rope with tension mg/2 connected to the bucket. What then must be the force applied to to the other rope?
Sorry about formatting I'm on my phone
