Putnam and Beyond Problem 113 Solution
  • Thread starter Thread starter ehrenfest
5 replies · 2K views
ehrenfest
[SOLVED] putnam and beyond prob 113
Let a,b,c be side lengths of a triangle with the property that for any positive integer n, the numbers a^n, b^n, and c^n can also be the side lengths of a triangle. Prove that the triangle is necessarily isosceles.
I can do the case where a,b>1 and c<1 using the triangle inequalities a^n+c^n>b^n>a^n-c^n and squeezing but I cannot do the case where a,b,c>1 or a,b,c<1 unfortunately. Can someone give me a hint?
Hi ehrenfest! :smile:
Hint: if it's not isoceles, then name the sides so that a > b > c > 1.
You need to find an n such that a^n > b^n + c^n. :smile:
I got it. When n is large enough
[tex]\frac{c}{a-b}\left( \frac{c}{a} \right)^{n-1} < 1[/tex]
or
[tex](a-b) a^{n-1} > c^n[/tex]
Then we have
[tex]a^n -b^n = (a-b)(a^{n-1}+ \cdots b^{n-1}) > (a-b)a^{n-1} >c^n[/tex]
which is what we want. Thanks. Please confirm that this is correct.
hmm … a bit complicated …
For a simpler proof …
Hint: forget c, and just find an n with a^n > 2(b^n). :smile:
That works too.
EDIT: and wow that is much simpler since you avoid dividing into cases
Yes … very simple questions often have very simple answers if you look long enough! :rolleyes:
Moral … simplify the problem as much as possible … then solve it! :smile:
