fluidistic
- 283
Ok, this is something related to a real life problem, more precisely a laboratory experiment.
Say that the temperature of the room is 25°C. I have a calorimeter. I chose to put 250 g of water at 27.5 °C inside it. But as it is not a perfect calorimeter, say I've calculated (by the least squares method and by doing a long experiment) its equivalent mass in water to be 50 g. In other words, the calorimeter behaves like absorbing the same heat as 50 g of water.
Now I want to put a 20 g ice cube in order to calculate the latent heat of water.
To find it, I think of using the formula Q_1+Q_2=0. Or, in details : (M+\pi)c_{\text{water}}(T_f-27.5)+mc_{\text{ice}}(0-T_i)+mc_{\text{water}}(T_f-0°C)+mL_{\text{ice}}=0 where T_i is the initial temperature of the ice (which might be below 0°C), T_f is the final temperature of the calorimeter and the melted ice cube, M is the initial mass of water, that is 250 g, \pi is the equivalent mass in water of the calorimeter.
After measuring T_f, the only unknown in the equation would be L_{\text{ice}}.Ideally, what I would like is to have a \Delta T such that the room temperature (T_r) is such as T_r-\frac{\Delta T}{2}<T_r<T_r+\frac{\Delta T}{2}.
\Delta T is the difference of temperature between the initial water+calorimeter temperature and the final temperature of the water+calorimeter+melted ice cube.
So ideally, in my example I would like to have T_f=25°C-2.5°C=22.5°C, although I know it will likely not happen in my example.
I wrote all this to ask... am I making any error somewhere? I feel I'm right on everything, but I might miss something. Especially regarding the equation (M+\pi)c_{\text{water}}(T_f-27.5)+mc_{\text{ice}}(0-T_i)+mc_{\text{water}}(T_f-0°C)+mL_{\text{ice}}=0.
Thank you infinitely.
