Quadratic inequality-interval notation
1 reply · 4K views · last reply
Torshi
quadratic inequality--interval notation..
2x^2<-x+10
Solve inequality and put into interval notation
interval notation
I don't even know where to start. I set it equal to zero -2x^2-x+10=0
It's fine to start by solving the corresponding equation. The solutions of the equation become "boundaries," if you will, of sets of numbers that are solutions to the inequality. Suppose there are two solutions, a & b, with a < b. Then you would have 3 potential range of numbers to test.
Pick a value less than a and test into the original inequality. If the result is a true statement, then x < a would be in the solution set.
Then pick a number between a and b and test. If it works, then a < x < b is in the solution set.
Finally, pick a number in greater than b. If it works, then x > b is in the solution set.
