Quantities without unit of measure
36 replies · 6K views
Caio Graco
Quantities without unit of measure are:
A) Necessarily scalar
B) Necessarily vector
C) Can be scalar or vector
D) They are neither scalar nor vector
Justify your answer!
No equations
For example, the refractive index of a medium is a number without unit of measure. If it were to risk between climbing or vector, I'd say climb. However, anywhere scale is defined by a number accompanied by its unit. Therefore, the index of refraction would not be scalar and since it has no orientation, it is also not a vector, so what would it be?
No equations
The simple refractive index of an isotropic dielectric is a scalar, correct. But what if the dielectric is not isotropic...? :smile:
Is it even that the refractive index of an isotropic dielectric is a scalar? We are sure that this is a pure number, that is, without a unit of measure. But does not having unity still characterize it as scalar?
And in case if the dielectric is not isotropic, there will be a tensor that will represent the index of refraction.
It is certainly a scalar (no direction) in the vacuum, and also in isotropic media. https://en.wikipedia.org/wiki/Relative_permittivity#Terminology
Very good! So I think you have what you need to answer the question now (a good example). :smile:
So to close, in case you were to mark my initial question, you would mark the letter A. Is that it?
haruspex said:
Is a tensor an example of a vector?
I think it's the reverse: a vector is an example of a tensor.
Yeah, looking through the Wikipedia list doesn't seem to show vectors...
Does the wiki show any scalar list that shows refractive index as an example? I do not think so.
Yeah, looking through the Wikipedia list doesn't seem to show vectors... https://en.wikipedia.org/wiki/List_of_dimensionless_quantities
Seems to me that dimensionless constants associated with "the universe" are necessarily scalars by the principle of isotropy.
For attributes of materials, they will surely be scalars or tensors. (And in the scalar case, arguably just a degenerate tensor.)
Can't think what else...
haruspex said:
Sure, but that does not make a dimensionless tensor an example of a dimensionless vector.
A dimensionless vector must be an example of a non-dimensional tensor. I believe.
Yes, but that does not help you. You have found a dimensionless tensor, and the example you need is of a dimensionless vector. So you would need to argue that a tensor is an example of a vector.
What letter would you mark for the initial problem? Please...
Can I say that a normal one of a surface which I wish to calculate, for example, the electric flow is an example of dimensionless vector quantity?
I'm sorry for my english.
Electric flow would have dimensions (like Coulombs per second), but you bring up an interesting point. Unit vectors by definition do not have units... I don't know if they qualify as dimensionless "quantites", though. https://en.wikipedia.org/wiki/Unit_vector
Not a problem. It's much better than any of my own foreign language skills. :smile:
A single quantity without unit is only a number, that is another word for a scalar. But one can always regard several of them and arrange them as a vector of scalars. The question then is, whether such an arrangement can be considered to be a quantity or not. The refractive index is a good example as well as a non isotropic medium is. One could as well consider ##(r,s,t) = \textrm{ refractive index air to (oil, water, glas) }## as a single quantity instead. The answer is thus a matter of definition, so it's probably more of a question what the teacher wants to hear rather than a question with a unique answer, except for "quantity" is defined somewhere.
I think you misunderstood me. I did not refer to the unit of electric flow, but to the fact that normal has no unit of measure, to be a unit vector. And the question is whether normal would be an example of dimensionless vector quantity.
My English is all coming from google translator. I know nothing of English, only Brazilian Portuguese hehehe.
This question was elaborated by me!
Caio Graco said:
See the first paragraph of this pdf and notice that it is said that to be a scalar magnitude is necessary to have unit of measurement.
Is it correct?
http://zeus.plmsc.psu.edu/~manias/MatSE447/03_Tensors.pdf
O.k. But as in the example of a refractive index, a quantity can also be a number without a unit. Here you measure a quotient and the units cancel out. This means, unit or not isn't the question to distinguish between scalars and vectors. Nor is it a matter of dimension. Mathematically a single number (scalar) can also be a one-dimensional vector. Physically a dimensionless scalar, is a number as the refraction index is. The hydrostatic pressure has a physical dimension (pressure) and temperature is also a physical dimension.
What is meant in the paper is the following:
Say we have the hydrostatic pressure ##H(\vec{x}_0)## and the temperature ##T(\vec{x}_0)## at a point ##\vec{x}_0## on earth.
  • ##H_0=H(\vec{x}_0)## as well as ##T_0=T(\vec{x}_0)## are scalars, because they don't have a direction, only a scale - a number. They are not dimensionless and both have a unit, although they are scalars.##\\##
  • ##(H_0,T_0) = (H(\vec{x}_0),T(\vec{x}_0))## is a vector of scalars with two different dimensions.##\\##
  • ##\{\,(\,H(\vec{x})\,,\, \vec{x}\,)\,\vert \, \vec{x} \textrm{ a point on Earth }\}## is a scalar field: each point ##\vec{x}## has an associated scalar ##H(\vec{x})## which gives us a field of scalars. Usually the entire scalar field is also briefly noted as ##H## or ##H(\vec{x})##.##\\##
  • ##\{\,(\,(H(\vec{x}),T(\vec{x}))\,,\, \vec{x}\,)\,\vert \, \vec{x} \textrm{ a point on Earth }\}## is a vector field: each point ##\vec{x}## has an associated vector ##(H(\vec{x}),T(\vec{x}))## which gives us a field of vectors; each vector being a pair of scalars. Usually the entire vector field is either written as ##(H,T)=(H(\vec{x}),T(\vec{x}))## or abbreviated with another letter ##V##.##\\##
  • If we define ##\vec{w}(\vec{x}_0)## as the vector of wind at a point ##\vec{x_0}## on earth, then ##\vec{w}## is the classical vector with a direction, where the wind blows, and a magnitude, how strong the wind blows.##\\##
  • If we define ##\{\,(\,\vec{w}(\vec{x}),\vec{x}\,)\,\vert \,\vec{x} \textrm{ a point on Earth }\}## then we get a classical vector field, that is to each point ##\vec{x}## an associated vector of wind ##\vec{w}(\vec{x})##. Usually this construction is only denoted by, e.g. ##W## or ##W(\vec{x})\,.## ##\\##
Is it correct?
I would not take that web page as an authoritative source on such fine distinctions. It seems fairly low level.
A good example of a naturally occurring dimensionless scalar is the Reynolds number. Another is π.
Do you know of any reliable sources on the WEB that cite the examples you mentioned, explicitly called them scalar quantities?
Why do you insist on this wording? It's important to understand what is meant by scalar, vector, quantity, unit and dimension. Among these, quantity is certainly the least rigorously defined term.
