Quantum mechanical equation of motion?
The discussion centers on the quantum mechanical equation of motion for a density matrix represented as \(\rho(t) = \Sigma_a |\Psi_a(t)\rangle P_a \langle \Psi_a(t)|\). Participants clarify that the trace of the density matrix, \(Tr(\rho) = 1\), and the expectation value of an operator \(K\) is given by \(\langle K \rangle = Tr(\rho K)\). The equation of motion is defined as \(i\hbar\frac{\partial \rho(t)}{\partial t} = [H,\rho(t)]\), which is derived from the time-dependent Schrödinger equation. The discussion emphasizes that this equation describes the time evolution of the density operator, linking it to broader concepts such as Ehrenfest's theorem.
  • Understanding of density matrices in quantum mechanics
  • Familiarity with the time-dependent Schrödinger equation
  • Knowledge of commutators in quantum mechanics
  • Basic concepts of Ehrenfest's theorem
  • Study the derivation of the time-dependent Schrödinger equation
  • Learn about the properties and applications of density matrices
  • Explore the implications of Ehrenfest's theorem in quantum mechanics
  • Investigate the role of Hamiltonians in quantum systems
Quantum mechanics students, physicists, and researchers interested in the dynamics of quantum systems and the mathematical framework of quantum mechanics.
jeebs
I have this question that gives me a density matrix \rho (t) = \Sigma_a |\Psi_a(t)\rangle P_a \langle \Psi_a(t)| and all I am told is that it is just for some "quantum system" and that Pa is the probability of the system being in the state |\Psi_a(t)\rangle
I am asked to first show that the trace Tr(\rho) = 1 and that the expectation value of some operator K is \langle K \rangle = Tr(\rho K), which was fairly straightforward. Then the part I am having problems with is that is asks me to "show that the equation of motion is i\hbar\frac{\partial \rho(t)}{\partial t} = [H,\rho (t)] ".
I am told nothing about what situation this "equation of motion" might apply to. This is literally everything the question tells me and I have never been asked to do this before in a quantum sense. The only kind of equation of motion I have ever had to set up was in a classical sense like, say, a damped spring, say m\frac{d^2x}{dt^2} = -c\frac{dx}{dt} - kx and clearly this is done in terms of forces, which don't seem to get used in quantum mechanics.
So in short, I have no idea what I am supposed to make of this, or what use calculating that trace and expectation value was, if that has any relevance. Any suggestions on how to approach this?
Thanks.
In this case, the term "equation of motion" is being used to refer to the time evolution of the density matrix. The precise situation or system would be encoded in the Hamiltonian. However, the details are unnecessary, since the result you're asked to prove follows directly from the time-dependent Schrödinger equation.
so what, I'm basically just being asked to work out what the commutator is, and what density operator's time derivative is, and if I see that these two things are equal then I've done what I was being asked?
anyway why do we say that the equation of motion is the time derivative of this density operator anyway? I'm no expert in QM but that doesn't immediatley scream "motion" to me.
All I know of a density operator is that it is a statistical mixture of projection operators. What has taking the time derivative of a set of projection operators got to do with motion?
Like I said, the term "equation of motion" is being used here in a broader sense to label an equation that describes the time evolution of some quantity. In your example, you had an equation of motion that described the time evolution of the displacement of a spring. In QM, the time-dependent Schrödinger equation describes the time evolution of the wavefunction, so in that sense it is also an equation of motion. In a certain sense, the "motion" involved is that in the space of solutions to the time-independent Schrödinger equation.
This problem involves the time evolution of the density operator, which is a specific case of a broader result called Erenfest's theorem, which describes the time evolution of a general operator.
  • · Replies 0 ·
  • · Replies 32 ·
  • · Replies 0 ·
