Quantum Mechanics and Electrodynamics/Electrostatics
The discussion centers on the relationship between quantum mechanics and classical electrostatics, specifically addressing the uncertainty principle and its implications for measuring position and momentum of particles like electrons and protons. Participants highlight that the small value of Planck's constant (h) allows classical theories to remain effective at macroscopic scales despite the inherent limitations of quantum mechanics. The uncertainty relation, expressed as ##\sigma_x \sigma_p \ge \hbar/2##, illustrates the trade-off between position and momentum accuracy, which remains manageable for larger particles like protons compared to electrons.
  • Understanding of quantum mechanics principles, particularly the uncertainty principle.
  • Familiarity with classical electrostatics and dynamics.
  • Knowledge of Planck's constant (h) and its significance in quantum theory.
  • Basic grasp of particle physics, including properties of electrons and protons.
  • Research the implications of the uncertainty principle in quantum mechanics.
  • Explore classical electrostatics and its limitations in the context of quantum phenomena.
  • Study the significance of Planck's constant in various physical theories.
  • Examine the differences in behavior between electrons and protons under quantum mechanics.
Physicists, students of quantum mechanics, and anyone interested in the interplay between quantum theory and classical physics, particularly in the fields of particle physics and electrostatics.
WWCY
Hi all, I have a question relating to the title above.
The uncertainty relation tells us that an electron that is localised (in terms of its PDF) is space has a large uncertainty in momentum space. However in classical electrostatics/dynamics we seem to make attempts to do things like approximating the magnetic field caused by an electron moving at a given velocity from A to B.
Isn't this a little wonky since we are assuming that we know position and momentum at the same time? If so, is there a reason why classical theory still holds up pretty well (slight understatement)?
Thanks in advance!
Because h is small.
Thanks for your response.
Vanadium 50 said:
Because h is small.
Do you mind elaborating a little on what this means? I'm afraid I don't follow.
If h were zero, QM would look like classical physics.
As @Vanadium 50 said above, the reason it works is because h is small in terms of the scale where classical theory holds up well. Recall that the uncertainty principle does not merely tell us that we cannot know position and momentum at the same time, but it also puts specific constraints on our knowledge of position and momentum. Specifically: ##\sigma_x \sigma_p \ge \hbar/2##.
So if we have an electron whose velocity we prepare to an accuracy of 1 m/s then we simultaneously prepare its position to an accuracy of 58 microns. If it is a proton with the same velocity then we can also prepare its position to an accuracy of 32 nanometers. On classical scales that works OK.
Thanks a lot!
  • · Replies 39 ·
  • · Replies 376 ·
23K
