(Quantum Mechanics) Gaussian Distributions, Expected Values, and Sketches
The discussion focuses on solving a Gaussian distribution problem defined by the equation ρ(x) = Aexp[(-λ^2)(x-a)^2]. Participants addressed three main tasks: normalizing the distribution to 1, calculating the expected values and , and sketching the graph of ρ(x). The normalization constant A was determined to be 2λ/√π. Participants encountered challenges with the integration required for expected values and the graphical representation of the Gaussian function, particularly in understanding the relationship between the average value, standard deviation, and the shape of the distribution.
  • Understanding of Gaussian distributions and their properties
  • Familiarity with integration techniques, particularly Gaussian integrals
  • Knowledge of expected values and standard deviation in probability theory
  • Basic skills in sketching mathematical functions
  • Study Gaussian integrals and their applications in probability theory
  • Learn techniques for calculating expected values using integration
  • Explore the properties of standard deviation and its significance in data analysis
  • Practice sketching Gaussian functions and understanding their characteristics
Students and professionals in physics, mathematics, and statistics who are working with Gaussian distributions, as well as anyone seeking to deepen their understanding of probability theory and statistical analysis.
QuantumBunnii
Consider the gaussian distribution
ρ(x) = Aexp[(-λ^2)(x-a)^2] ,
where A, a, and λ are positive real constants.
(a) Find A such that the gaussian distribution function is normalized to 1.
(b) Find <x> (average; expected value) , <x^2>, and σ (standard deviation).
(c) Sketch the graph of ρ(x)
Gaussian integrals (integrated from 0 to infinity):
∫x^(2n)exp[(-x^2)/a^2]dx = \sqrt{\pi}\frac{(2n)!}{n!}(\frac{a}{2})^(2n+1)
∫x^(2n+1)exp[(-x^2)/a^2]dx = \frac{n!}{2}a^(2n+2)
(a) This part didn't give me any problems (I think), but I would like to make sure the general methodology is correct.
In order to normalize the distribution function to 1, you would merely set the integration over all space equal to 1:
∫Aexp[(-λ^2)(x-a)^2]dx = 1 (all space)
Since the only variable that differs from the given gaussian integral is the (x-a) term in the exponent, we can change the variable to, say, y = x-a and get dy = dx. Plugging everything in straight from the gaussian integral and multiplying everything by 2 (the given integrals are from 0 to inf., whereas this is from negative inf. to positive inf.), A is readily obtained as \frac{2λ}{\sqrt{\pi}} .
(b) This is where I start to have trouble.
The average, <x> is given as follows:
∫xρ(x) dx = ∫xAexp[(-λ^2)(x-a)^2]dx (all space)
and this is as far as I can get. My problem is essentially one of mathematics: I don't know how to solve this integral. Just as in the previous problem, it is extremely close to the given gaussian integral, expect that-- in this case-- we can't employ a change of variables because we have the 'x' sitting in front of everything. The same will, of course, apply to <x^2>, and-- since σ = <x^2> - <x>^2-- this inhibits me from moving any further.
(c) is again a problem which arises from my lack of mathematical competence. I'm simply not sure how to sketch gaussian distribution functions. Could it be that the average (or, 'expected') value represents the peak of this function? (If so, I don't understand why-- as the average value is not necessarily the most probable value). And perhaps the standard deviation σ represents something akin to the full-width-at-half-maximum?
Or maybe I simply need to plug in a variety of points to get a general idea?
Thanks for any help~
P.S. Sorry about the formatting of the equations. I'm not sure how to make them look any better. :p
[strike]Your post has some conflicting information here: you say you want "∫Aexp[(-λ^2)(x-a)^2]dx = 1 (all space)", which to me would imply ##-\infty < x < \infty##, but then you say that x is from 0 to infinity? Could you clarify which is the correct case?
I would normally assume that for some reason in this problem "all space" is just 0 to infinity, but I would to double-check because if that is really the case you run into trouble when you change variables: if the integral over x is from 0 to infinity, then the integral over y = x-a is from -a to infinity. This is not a simple integral, and the resulting normalization constant would involve the error function (which is defined in terms of a Gaussian integral).
So, I would suggest you double-check your limits. If they are indeed from x=0 to infinity, then you will need to know the error function to express the normalization constant.[/strike]
Ok, re-reading your post it looks like your integral limits are from ##x=-\infty## to ##\infty##, you're just using the symmetry to do the integral from 0 to ##\infty##, correct? That's fine as long as you do your change of variables before you double the integral and change the limits to 0 to ##\infty##.
You can certainly employ a change of variables here. The factor of x in the integrand would just mean you have to replace it by (y+a), so you would end up splitting your integral into two terms.
The average value is not necessarily the most probable value, but that doesn't mean it can't be in some cases. You can compute both in this case to see if they match.
To learn how to do LaTeX formatting of equations, see this post.
Sure. The given guassian integrals are from 0 to inf., but the problem requires us to integrate from negative inf. to inf. (this is also why I said we would need to multiply by two).
Perhaps I should have simply listed the integrals from negative inf. to inf. in the outset, so that they agree. I guess I was really trying to ask if multiplying by a factor of two does in fact correct the difference in the lower limit from 0 to negative inf. in the two integrals.
Mute said:
You can certainly employ a change of variables here. The factor of x in the integrand would just mean you have to replace it by (y+a), so you would end up splitting your integral into two pieces.
You're right-- I don't know what I was thinking. :)
I intuitively dismissed the change of variable technique here and ended up trying to find another method for hours. Winter break was much too long x_x
Thanks for the help!
  • · Replies 19 ·
21K
