Quantum Mechanics Positional Operator
The discussion centers on the expectation value of the positional operator \(\hat{x}\) in quantum mechanics, specifically for a particle in a one-dimensional box described by the wave function \(\Psi_{n}(x) = \sqrt{2/L} \sin(\pi n x / L)\). Participants confirm that the expectation value \(\langle \hat{x} \rangle\) equals \(L/2\) after resolving integration errors. The correct integral setup is \(\int_0^L \frac{2x}{L} \sin^2(\pi n x / L) dx\), leading to the conclusion that the additional terms vanish when evaluated at the limits, confirming \(\langle \hat{x} \rangle = L/2\).
  • Understanding of quantum mechanics principles, particularly wave functions
  • Familiarity with the concept of expectation values in quantum systems
  • Proficiency in integral calculus, especially integration by parts
  • Knowledge of trigonometric identities and their application in integrals
  • Study the derivation of expectation values in quantum mechanics
  • Learn about the particle-in-a-box model and its implications
  • Explore advanced integration techniques, including integration by parts
  • Investigate the role of boundary conditions in quantum wave functions
Students and educators in quantum mechanics, physicists working with wave functions, and anyone interested in the mathematical foundations of quantum theory.
UbikPkd
\Psi_{n}(x) = \sqrt{2/L}sin(\pinx/L), 0 \leqx \leq L
\Psi_{n}(x) = 0, x<0, x>L
\pi is meant to be just normal, not superscript, sorry
n is an integer
show that <\hat{x}> = L/2
<\hat{x}> is the expectation value of the positional operator \hat{x} right?
\hat{x} \Psi= x \Psi i think so...
\int2x/L sin ^{2}(\pi2nx/L) dx
which gets me L/2 - L^{2}/4n^{2} \pi^{2}
but it is supposed to be just L/2 sigh...
any help will be much appreciated :confused:
n is an integer
Hint: Put everything inside a single tex quote! As in
\int_0^L ~\frac{2x}{L}~ \sin^{2}(\pi 2 n x / L) dx
This seems right (you used the limits to be 0 and L, right?)
Can you show your steps? You must have made a mistake in the integration.
ok here goes, i was wary of doing that because, as you can see, that was my first post and it took forever!
sorry that last one should have read:
\int_0^L ~\frac{2x}{L}~ \sin^{2}(\pi n x / L) dx \int_0^L ~\frac{x}{L}~- ~\frac{x}{L}~ \cos(2 \pi n x / L) dx
integrating by parts:
~\frac{x^{2}}{2L}-(~\frac{x}{L}~~\frac{L}{2n \pi }~\sin(~\frac{2 n \pi x}{L}~)- \int_0^L ~\frac{L}{2 n \pi L}~\sin~\frac{2n \pi x}{L}~dx )\left[ ~\frac{x^{2}}{2L}-~\frac{x}{2n \pi}~\sin(~\frac{2 n \pi x}{L}~)- ~\frac{L}{4 n^{2} \pi^{2}}~\cos~\frac{2n \pi x}{L}~ \right] (between L and 0)
= ~\frac{L}{2}~ - ~\frac{L}{4 n^{2} \pi^{2}}~
but it should just be ~\frac{L}{2}~ ?
you have basically worked out the answer, it's just that you forgot that the when zero is put in as a limit in the second part (the cosine part), it gives 1 aswell. i.e. cos(2 \pi n) = cos(0), so the second part that you got disappears, leaving you with just the L/2 which is what you want.
&lt;x&gt; = ~\frac{L}{2}~ - ~\frac{L}{(2 \pi n)^2}~ + ~\frac{L}{(2 \pi n)^2}~
AHHHHHH I've done that so many times, still i haven't learnt, thank you very much, both of you!
nrqed
i read your blog, a few days ago id never done any quantum, they threw us in by asking for the wave function of the 'particle in a box' . It was a steep learning curve that lasted all night and several litres of coffee...got there in the end!
nrqed
That's ok. Only too glad to help. Steep learning curves are the best in the long run, take my word for it :P
  • · Replies 0 ·
  • · Replies 26 ·
