Quantum Question: Help Understanding GUP Proof in Document
  • Thread starter Thread starter latentcorpse
    Quantum
5 replies · 2K views
latentcorpse
Just reading through my notes and found a step I can't follow:
If you look at p3 of the follwing document, one of the lines in the proof of the Generalised Uncertainty Principle has a (2) next to it. I can't get from the line before it to that line.
Can anyone help me out?
http://www.ph.ed.ac.uk/teaching/course-notes/documents/64/786-lecture5.pdf
thanks
Use, equation (1) on that page to show that [tex][\hat{X},\hat{Y}]=[\hat{A},\hat{B}][/tex], then use the definition of expectation value
hey. thanks. i have another question about it though.
in the line before (2), how does the [itex](\Delta \hat{A}_t)^2[/itex] term work? Surely when we square [itex]\hat{X}[/itex], we get [itex](\Delta \hat{A}_t)^2[/itex] as well as other stuff arising from the cross terms?
also in the very last line, where does he get the [itex]i[/itex] in the RHS from - I'm assuming it's so that we end up with a [itex]\geq[/itex] not a [itex]\leq[/itex] but i don't follow it...
thanks
By definition, [tex](\Delta \hat{A}_t)^2=(\hat{A}-\langle\hat{A}\rangle_t)^2=\hat{X}^2[/tex]
And the [itex]i[/itex] is just a way to account for the negative sign since [tex]\langle i [\hat{A},\hat{B}]\rangle_t^2=i^2\langle [\hat{A},\hat{B}]\rangle_t^2=-\langle[\hat{A},\hat{B}]\rangle_t^2[/tex]
but [itex]\Delta \hat{A}_t = \sqrt{\langle \hat{A^2}_t \rangle - \langle \hat{A}_t \rangle^2}[/itex]
so why do you get what you've written?
The two definitions are equivalent:
[tex](\hat{A}-\langle\hat{A}\rangle_t)^2=\hat{A}^2-2\hat{A}\langle\hat{A}\rangle_t+\langle\hat{A}\rangle_t^2[/tex]
[tex]\implies \int_{-\infty}^{\infty} \Psi^{*}(x,t)(\hat{A}-\langle\hat{A}\rangle_t)^2\Psi(x,t)dx=\int_{-\infty}^{\infty} \Psi^{*}(x,t)\hat{A}^2\Psi(x,t)dx-2\langle\hat{A}\rangle_t \int_{-\infty}^{\infty} \Psi^{*}(x,t)\hat{A}\Psi(x,t)dx+\langle\hat{A}\rangle_t^2\int_{-\infty}^{\infty} \Psi^{*}(x,t)\Psi(x,t)dx[/tex]
[tex]=\langle\hat{A}^2\rangle_t-2\langle\hat{A}\rangle_t^2+\langle\hat{A}\rangle_t^2=\langle\hat{A}^2\rangle_t-\langle\hat{A}\rangle_t^2=(\Delta\hat{A}_t)^2[/tex]
[tex]\implies (\Delta\hat{A}_t)^2=(\hat{A}-\langle\hat{A}\rangle_t)^2[/tex]
since they both integrate to the same thing
