Does Quantum Tunneling Explain Electron Positioning in Atomic Orbitals?
The discussion centers on the concept of quantum tunneling and its relation to electron positioning in atomic orbitals, specifically addressing the behavior of electrons in hydrogen atoms. Participants clarify that while wave functions indicate electron probability distributions, tunneling does not occur within atoms due to the attractive potential of the nucleus. The weak force governs interactions such as electron capture, which is a slow process, and the Schrödinger equation is essential for understanding these phenomena. Key points include the distinction between classical forbidden regions and the nature of tunneling in atomic systems.
  • Understanding of quantum mechanics principles, particularly wave functions and the Schrödinger equation.
  • Familiarity with atomic structure, specifically hydrogen atom wave functions and electron orbitals.
  • Knowledge of fundamental forces in physics, including electromagnetic and weak forces.
  • Concept of quantum tunneling and its implications in particle physics.
  • Study the Schrödinger equation and its applications in quantum mechanics.
  • Research the concept of electron capture and its role in weak interactions.
  • Explore quantum tunneling in various physical systems, including alpha decay.
  • Investigate the differences between classical and quantum mechanical interpretations of particle behavior.
Physics students, quantum mechanics researchers, and anyone interested in the behavior of electrons in atomic structures and the implications of quantum tunneling.
Buckeye
Wave functions that produce two lobes of electron probability on opposing sides of the core indicate that our point-like electron must tunnel through the nuclear core when the point charge moves to the opposing lobe. I don't understand what is the driving force for this process? Does this process occur at near light speed?
No, when you derive the wave functions for electron wavefunctions, the nucleus are regarded to be point like (recall how small the nucleus is compared with the 'seize' of an atom).
Then you must take notice of the radial wave functions of the hydrogen atom looks like, only the ground state (n=1, L=0) have a non zero probability to be located at r=0 (i.e inside the nucleus). Then you must know your particle interaction rules, the electron interact via the weak force to make the process (electron capture): http://en.wikipedia.org/wiki/Electron_capture
So this process is a weak process, i.e it goes very slow. And in reality, since the nucleus has a certain size, L and M shell electrons can be captured, but that process is quite small compared to K shell capture.
The thing is how the wave function works, and how we really want to interprent everything that the electron is moving around etc. One has to use the formalism and compare with experiments.
I hope I at least shed some light on how atomic electrons interact with the atomic nucleus.
http://scienceworld.wolfram.com/physics/InverseBetaDecay.html
http://www.cyberphysics.pwp.blueyonder.co.uk/graphics/diagrams/Feynman/Feynmanelectroncapture.gif
http://en.wikipedia.org/wiki/Weak_interaction
Also, the concept of tunneling is this:
If a particle can be located at a classical forbidden region, it has undergone tunneling. I.e let the energy of the particle be E, and the potential energy be V. if E<V, then the region is called classical forbidden.
But in the atom, the potential is attractive (the one that the nucleus are generating) so the electron has no potential barrier to overcome, so tunneling is not occurring in the atom. The nucleus can bind the atom, and there exists an (infinite) number of bound states.
That was the electromagnetic force, the weak force you cannot have potentials since it is a totally different force than the electromagnetic one.
So the main thing about tunneling is that when you have a region where the particle can't be classically, one can solve the Schrödinger equation and find the transmission probabilities and so on. The first example of tunneling is alpha decay, the model is that an alpha particle is inside the nucleus and since it is charged, the repulsive EM potential (that outer lying protons will create) will keep the alpha inside the nucleus. However, there is a small probability of tunneling through this barrier.
If you want, I can give you plenty of material and references for all of this. But I think you know all of this, you are much older than me and you are about to make this theory of everything :-)
Hmmmm,
I did not quite find the answers to my questions. Please re-read my questions and try again.
Thanks!
Vince
Buckeye said:
Hmmmm,
Thanks!
Vince
Hmmm, perhaps you didn't find any answers to your question because your question may be based on false premise. Could you start by explaining what you understand by Quantum Tunnelling and we'll take it from there?
Or you could just have not found the answer becasue you weren't looking hard enough. Re-read MG's posts and try again.
Buckeye said:
Hmmmm,
Thanks!
Vince
The point is that your question was based on wrong understanding of the tunnel effect and how the physics of the atom works and refreashing our defenition of a wave function.
Are you asking how fast the information travels? As in the two-photon state example in bells inequality in the 80's ?
If not, then the underlying physics behind the wave function are the Schrödinger equation and the quantum mechanical poisson bracket. (I don't understand what is the driving force for this process?)
OK. Thanks.
My reading suggests that Quantum Tunneling accounts for (or explains) the ability of the point-charge electron to appear on both sides of the corresponding nucleus for any L>0. Is this true?
I think you mean something similar to https://www.physicsforums.com/showthread.php?t=234989"
I think that you can get a similar situation with certain molecules like NH3 if I remember correctly. The N can tunnel from above the plane formed by te 3 H's to below and that tunnelling rate is elated to the energy diffeenceof the two eigenstates, the eigenstates being the symmetric and anti-symmetric linear combinations of the N being above and below the plane.
That is a useful comparison, but that inversion can be stopped at low temperatures so it is probably not due to QT.
Buckeye said:
OK. Thanks.
1) there is no tunneling in the atom, the electron does not tunnel through the nucleus.
see my post #3
"But in the atom, the potential is attractive (the one that the nucleus are generating) so the electron has no potential barrier to overcome, so tunneling is not occurring in the atom. The nucleus can bind the atom, and there exists an (infinite) number of bound states."
2) there is an angular degree of freedom, the electron can move in theta and phi direction aswell. So in order to be located at the total opposite place in the atom, angular translation is also a possibility.
Have you worked out the shrodinger equation for the hydrogen atom yourself? It's quite easy :-)
What is "your reading" referring to?
  • · Replies 114 ·
11K
  • · Replies 36 ·
  • · Replies 21 ·
