Quaternionic Rays instead of Complex
  • Graduate
  • Thread starter Thread starter Antizzio
56 replies · 7K views
Antizzio
TL;DR
This guy fixed quantum mechanics like Kelly fixed Al Bundy's work bench.
Instead of Complex rays as states, he used quaternionic rays. Each quaternionic ray: (1) is a copy of spacetime (called a "possible world"); (1) is 4-dimensional, (2) has a natural FLRW metric built in; (3) is a Lie Group with a natural Haar measure; (4) looks loke an hourglass, flaring out towards past and future. And all this from a single requirement that logic of the observer is Boolean.
It's in Chapter 2 of the book
"Focus on Quantum Mechanics", Editors David E. Hathaway et al.
Chapter 2, "Geometric Modification of Quantum Mechanics"
Nova Publishers, Physics Research and Technology, N.Y. 2011, pp. 15-34,
ISBN 978-1-62100-680-0. Since it's $90, I was looking for pointers to a cheaper version. Thank you!
It does not look like standard Quaternionic Quantum Mechanics (as far as I know, it does not work very well, it just complicates computations enormously).
Can you list the author(s) of this chapter?
Antizzio said:
Vladimir Trifonov
I don't know if it will be helpful, but the author has written an earlier, easily available paper on this this topic:
GR-friendly description of quantum systems. I took a quick look and have to say, compared to a typical paper written by a theoretical physicist, this work is framed from the perspective of a mathematician, and dare I say, a philosopher. You might search Google Scholar to find follow-up citations.
Can he use this new formalism to describe black holes, the hydrogen atom, anything real?
Looks like it incorporates standard QM as a "degenerate case": two out of four dimensions are collapsed in each possible world. I couldn't get through the category-theoretic diagrams, but Grok, Gemini and ChatGPT all say it checks out OK
Please keep in mind that AI cannot be used as a reference in the technical PF forums. Thanks.
Right, you cannot trust those guys, my apologies.
Goodness, it was something! But I think I've got it: If we accept for a second that spacetime is H* (nonzero quaternions), we get this in exchange: (1) natural Haar measure on H* (group multiplication, the author thinks it is more fundamental than Lebesgue, because it does not depend as much on Axiom of Choice, and can be build conctructively; (2) natural FLRW metric, which shapes it into an hourglass with the "waist" (3-sphere slice) going through the identity of H*; (3) FLRW metric induces a standard Lebesgue measure, which, the author feels, is less fundamental.
At the end of the paper he hints on Haar being responsible for structures at large scales, but it is not developed further in the paper (perhaps the book version is more complete? Please check this, if you have access to it). But if we roughly continue along these lines, Haar is responsible for pure spacetime (vacuum) volume, while Lebesgue measures matter density. Haar volume of the "waist" is nonzero, and since all other 3-sphere slices are produced by translations along left (and right) invariant vector fields, and Haar is also invariant, this means that Haar volume of 3-slices is constant. In the early universe matter density is huge compared to Haar. But Lebesgue dilutes rapidly and Haar catches up and eventually overtakes it, producing accelerated expansion. Please tell me where I am wrong on this, but doesn't it look like exactly like dark energy? Another thing, you can make the Haar volume as small as you wish, but it is never zero. This looks to me like a solution of the Fine Tuning problem.
I applaud your enthusiasm, but the reality is, in the nearly 20 years since its publication, this paper has garnered a mere 7 citations in total. And of those, just 3 are (apparently) authored by physicists. The remaining cites appear to be from philosophers and a biologist(!). The brutal truth is that this work evidently has had no influence on any practicing relativist, cosmologist or particle physicist.
Exactly, sounds like normal statistics, considering contemporary fundamental physics situation.
I know about cosmology as much as the next guy, but are there any cosmologists in this forum, to address some of the stuff I mentioned?
I have understood a small part of what Trifonov is doing, and I'll describe it here so people can see how weird or imaginative it is. In ordinary quantum mechanics, you have a Hilbert space in which everything is complex-valued, and the physical states correspond to the "rays" in Hilbert space. Apparently there is a fiber-bundle interpretation of this, called "geometric quantum mechanics", in which all the rays are the base space, and you put the nonzero complex numbers above each of them, as the fibers. The whole point of associating the rays with physical states, is that any further complex-number factor becomes physically meaningless, though it can carry phase information about the difference between two physical states.
What Trifonov is doing, is the same thing for quaternionic Hilbert space - so once again, on a conventional perspective, physical states are rays in Hilbert space, and there is a quaternionic factor which drops out as physically meaningless. Trifonov focuses on the possible quaternionic coefficient of each ray, and as in geometric quantum mechanics, considers that there is a fiber of nonzero quaternions associated with each ray. But it's this quaternionic fiber which he claims is the space-time associated with each ray!
Now personally I just don't see this leading anywhere. To actually get a physical interpretation of a ray in Hilbert space, you have to pick some operators whose eigenvalues will be the allowed values of physical properties (the observables), and so forth; and until you pick some operators, there's nothing in Hilbert space to tell you e.g. the number of dimensions that physical space has. You can start with exactly the same Hilbert space, and with an appropriate choice of operators, you can be describing a quantum system in a space-time of any number of dimensions.
Trifonov is proposing that the dimension of physical space-time is determined, not by a choice of operators, but by the dimensionality of the division algebra in terms of which the Hilbert space inner product, etc, is defined. But as far as I can see, he never makes the connection at the quantum mechanical level. All he does is say, quaternions form a 4-dimensional manifold, and there's a natural metric on that manifold which is Lorentzian, so maybe that's space-time. The logic isn't there, to make the connection he wants to make.
Adler wrote a book, "Quaternionic Quantum Mechanics and Quantum Fields." Any overlap with Trifonov?
It's a big book I haven't spent much effort on. Trifonov doesn't appear in Adler's references.
But isn't the standard QM a particular case of his: both theories describe and predict (at least) the same stuff? Indeed, I believe that's one of the main claims of the paper. Otherwise, why would they bother publishing it twice? I did not yet get through all the math, but with a little ai help progress is being made. BTW, spacetime dimensionality is an axiom in both QM and GR, it does not come from any "choice of operators".
Can you give an example? This isn't something I'm familiar with.
Oh you would be surprised 🙃
No, standard quaternionic QM does not work, because it uses quaternionic Hermitian operators (real eigenvalues). Trifonov uses quaternionic anti-Hermitian operators, with quadruples of eigenvalues. His QM is reduced to complex QM with anti-Hermitian operators. In the complex case it just sign flip, but in quaternionic case it produces "wonderful things", which I am still studying. They don't want me to mention AI here, but they know about this stuff a lot (but be careful, though).
Yes, I purchased this text quite some time ago and put it down when it became apparent the concept was a wash. As to Adler referencing Trifonov's work, this would require a causality violation. Trifonov references Adler.
One is reminded that while all physics is mathematics, not all mathematics is physics.
Are you familiar with how quantum field theory is developed in textbooks? In a classical field theory, a field has a value at every point in space, and there is also a conjugate field momentum (rate of change of the field) at every point in space. In a quantum theory, via the correspondence principle, all these canonical variables turn into operators. For a field phi, there is a distinct operator "phi(x0,x1,x2,x3)" for each space-time point. Then the quantum theory is defined by specifying commutation relations among such operators and a Hamiltonian operator, for example.
But if we were studying fields in two space-time dimensions, the field operators would just have the form "phi(x0,x1)", if we were working in six space-time dimensions, they would have the form "phi(x0,x1,x2,x3,x4,x5)", and so on. Meanwhile the underlying Hilbert spaces are isomorphic, they are just infinite-dimensional.
So the point is that when you are defining a quantum field theory, it's the number of coordinate indices in the field operators that corresponds to the space-time dimension - and that is completely independent of properties of the Hilbert space, such as the use of complex numbers.
Enough to follow your post, yes.
I see, yes.
Doesn't claiming the isomorphism of the underlying Hilbert spaces for field theories in spacetimes of different dimensions ##d## violate the first Wightman axiom of QFT? That axiom states, in essence, that:
The states of the theory are unit rays in a Hilbert space ##\mathcal{H}\,##, that carries a unitary representation of the Poincare group.
Since the Poincare group ##ISO\left(d-1,1\right)## clearly depends on ##d\,##, how can ##\mathcal{H}\left(d=6\right)## be isomorphic (unitarily equivalent) to ##\mathcal{H}\left(d=2\right)##? While it's true that only the field operators can explicitly depend on the ##d## spacetime-coordinates, evidently ##\mathcal{H}## must be distinct for each ##d\,##. So it seems valid to ask, à la Trifonov: is there a reason why ##\mathcal{H}\left(d=4\right)## is singled out in our world?
Yes, there is
renormalize said:
So it seems valid to ask, à la Trifonov: is there a reason why H(d=4) is singled out in our world?
That reason is the main point of his work: "Because the logic of the observer is bivalent Boolean"
It's in the textbooks that all infinite-dimensional separable Hilbert spaces are isomorphic. They have the same countable infinity of dimensions, and that's it. You have to add extra structure, like singling out a specific family of automorphisms of the Hilbert space, to get a representation of an n-dimensional Poincare group as well. And the relevant family of automorphisms will be different, for different values of n.
That's good to know. Can you cite a reference that covers this? Thanks.
Hourglass Spacetime Toy Model is the Lie group of nonzero quaternions H*.
It has the following properties:
(1) it is a smooth real differentiable four dimensional manifold;
(2) as a Lie group it has a natural bi-invariant Haar measure;
(3) it has a natural FLRW metric (with a single free parameter, scale factor a(t));
(4) The FLRW metric induces the standard Lebesgue measure on H*;
(5) the metric shapes H* into an hourglass (in a higher dimensional Minkowski space), flaring out towards Past and Future, with the "waist" 3-sphere slice going through the identity of H* (the bounce point).
There is no classic big bang in this simplified description, just a bounce 3-sphere of finite size.
It is easy to notice an important feature of the Haar measure on H*: since all 3-sphere slices are produced by left and right invariant vector fields translations of the "waist", and our Haar measure is invariant, the Haar volume of 3-spheres remains constant, while Lebesgue volume increases towards Past and Future.
If we interpret the Haar and Lebesgue volumes as responsible for vacuum energy and matter densities, respectively, then:
(1) In the early universe (near the bounce point) matter density dominates.
(2) As universe expands, matter density (Lebesgue) dilutes rapidly, while vacuum energy density (Haar) stays constant.
Dark Energy: Vacuum energy density catches up to and eventualy overtakes matter density, producing accelerated expansion. That's a purely geometric source of dark energy.
Fine Tuning: Since vacuum energy density is always nonzero in this description, it also seems to produce a geometric solution to the fine tuning problem.
Hubble Tension: The rates of expansion are different before and after the "catch up" point.
Coincidense problem: the position of the "catch up" point.
Mature Structures too early: some of the stuff gets through the bounce point from the "other side".
Does all this make sense to a cosmologist?
It's a speculative model, which, as far as I can tell, has not gotten any real traction in the cosmology community. So the answer to your question is at best "too early to tell" and at worst "no".
No wonder: this has never been published or even mentioned anywhere except this particular thread. Thank you for your "too early to tell" opinion as a cosmologist, it's very nice of you.
I'm not a cosmologist. I based my opinion on what I know of cosmologists' reaction to the paper (i.e., basically none), and general things that apply to any new speculative research proposal.
