Queries about an electrostatic precipitator
  • Thread starter Thread starter sgstudent
    Electrostatic
4 replies · 2K views
sgstudent
In a precipitator, at the bottom is a negatively charged wire mesh while at the top is a set of rods at the two sides that are either earthen or positively charged. The purpose of the negative wire mesh is to charge the flue ash negatively by conduction then it is attracted to the positive rods at the side. But how can the ash get the charge? Isn't it an insulator of electricity? And even if it is water present, how can it gain the charge? In a electrolysis setup, the two reactions at the cathode and anode must occur at the same time so how can the cations be reduced there?
None
My physics tutor said that it can transfer electron by I just don't see how. Thanks for the help!
hmm. Well hair-combs and balloons are insulators. And from doing physics practicals with them, you can see that they gain charge. So is it so surprising that ash can get charged as well?
Oh but ash gets charged by direct touching (neutral touches charged redistribution then it becomes charged). But this method is a conductor mean of charging and not a insulators mean. So I don't get how it can simply be charged this way. As fair the water explanation, the process is like the electrolysis case, but anyhow a solution must be electrically neutral so the oxidation of the anion and reduction of cations must happen together but in this case it is not. So I'm pretty confused about this... Thanks for the help?
Ok, I wasn't sure how this equipment specifically works, so I looked it up and apparently there is a corona (i.e. ionisation) created around the negative electrodes, and it is by this method that the dust particles acquire electrons. Does this make sense to you? I'm not certain which bit you are concerned with.
