Question about existence of path-lifting property
  • Context: Graduate
  • Thread starter Thread starter MathLearner123
    Proof
The discussion revolves around the path-lifting property of covering maps in the context of algebraic topology. Participants explore the proof of a theorem regarding the existence of a continuous lift of a path from a space Y to a space X, where X is covered by Y. The conversation includes attempts to understand and prove the openness and closedness of a specific set related to the path-lifting property.
  • Homework-related
  • One participant expresses confusion about proving that the set A is both open and closed, which is necessary for showing that A equals the entire interval [0,1].
  • Another participant notes that the only subsets of [0,1] that are both open and closed are the empty set and [0,1], suggesting that proving A is non-empty, open, and closed would suffice.
  • Some participants discuss methods for proving openness, including showing that if a property holds at some t, it holds in a neighborhood of t, and for closedness, using sequences or showing the complement is open.
  • A participant proposes a sketch for proving closedness, involving sequences and constructing paths based on subsequences.
  • One participant introduces the concept of a "Lebesgue number" to clarify the path-lifting process, explaining how to define the lift on subintervals of [0,1] that map into evenly covered sets in Y.
  • Another participant elaborates on the proof of the Lebesgue number, discussing the continuity of a function that measures how far points are inside the cover.
  • A later reply suggests a method closer to the author's proof, focusing on extending the lift defined on subintervals to show it can be defined on larger intervals.
  • Finally, a participant expresses gratitude for the assistance and indicates they have reached an understanding.
Participants do not reach a consensus on the proof of closedness, as some express uncertainty about applying the sequence method. However, there is agreement on the necessity of proving both openness and closedness for the set A.
Participants acknowledge limitations in their understanding of algebraic topology, particularly regarding the specific proof techniques and definitions involved in the theorem.
MathLearner123
I'm reading "Complex Made Simple" by David C. Ullrich and here i have a problem with the proof of a theorem:
Theorem
Suppose that ##p : X \to Y## is a covering map. If ##\gamma : [0,1] \to Y## is continuous, ##x_0 \in X## and ##p(x_0) = \gamma(0)## then there exists a unique continuous function ##\tilde{\gamma} : [0,1] \to X## such that ##\tilde{\gamma}(0) = x_0## and ##p \circ \tilde{\gamma} = \gamma##.
This is the proof that author gives:
To prove the existence, let ##A## be the set of ##t_0 \in [0,1]## such that there exists a continuous ##\tilde{\gamma} : [0, t_0] \to X## with ##\tilde{\gamma(0)} = x_0## and ##p(\tilde{\gamma}(t)) = \gamma(t)## for all ##t \in [0, t_0]##. We need to show that ##A## is both open and closed.
I don't know how to show that ##A## is both open and closed, and as a mention I never took a Algebraic Topology class before. I tried to read some books, but can't understand very good what happens there and in the book mentioned by the author (A Basic Course in Algebraic Topology by William S. Massey) I don't find this proof for existence (that one from the book I don't understand). Thanks!
##A## is a subset of ##[0,1].## The only subsets of ##[0,1]## that are closed and open at the same time are ##\emptyset ## and ##[0,1]## because ##[0,1]## is a connected set. So if we can show that a) ##A\neq \emptyset ##, b) ##A## is open, and c) ##A## is closed, then ##A=[0,1].## If so, we can chose ##t_0=1## and we are done. I assume that ##0\in A## proves a). Remains to show b) and c).
Often, you show openness by proving if property holds at some ##t##, then it holds as well in a neighborhood of ##t##. Closedness can be shown either by showing the complement is open or through sequences, so that ##S## is closed if for every sequence ##s_n \in S##, if ##S_n \rightarrow s##, then ##s \in S##, i.e. the limit##s## of a sequence of points in ##S## is itself in ##S##.
I think I proved the openness. I will write it here as soon as I get home. I know that I can use sequences to prove the closedness but I don't know actually how to apply this on my exercise. Can you help me for closedness please?
Here's a sketch I would do, lots of details left to you
1.) if ##t_0\in A## then ##t\in A \forall t < t_0##.
2.) if ##t_k\to t## is a sequence with ##t_k\in A## for all k, then ##t\in A## unless ##t_k< t## for all k by (1)
3.) you can have pick a strictly increasing subsequence (unless ##t=t_k## eventually)
4.) use the paths given by that subsequence to build a path that stretches all the way to ##t##.
A classic technique is to take an arbitrary sequence and restrict it to a sequence that exactly reflects the interesting case you have to cover.
I like a little trick called a "lebesgue number", that he invented to clarify some of Riemann's integration concepts. If one has an open cover of a compact subset C of a metric space, there is a positive number e>0, such that the e-ball around any point of C is entirely contained in one of the open sets of the cover.
Then one pulls back to the closed unit interval, the open cover of Y by the "evenly covered" open sets that define the covering map. Then any subdivision of the unit interval into short enough subintervals will be such that each subinterval maps entirely into an evenly covered set in Y.
Then you just define the lift on one of these subintervals at a time. I.e. if a subinterval maps entirely into an evenly covered set of Y, the lift to X is uniquely defined by knowing where its initial point goes. just continue for every subinterval.
And this also proves uniqueness at the same time.
the point is that defining the lift on a subinterval [0,t1] is trivial if the subinterval maps entirely into an evenly covered set in Y. But [0,1] is a union of a finite chain of such subintervals, 0 ≤ t1 ≤ t2 ≤ ...≤ 1. so first define the lift on [0,t1], then on [t1,t2],.....
here's a proof of the lebesgue number: define a function d(x) on C as "how far inside the cover" is the point x. I.e. d(x) is the largest positive number e such that the open ball around x of radius e is entirely inside one set of the open cover. This function has positive values and is continuous, hence has a positive lower bound on the compact set C, the lebesgue number. (If you have trouble showing d is continuous, you can reduce the cover first to a finite subcover, and then d is the maximum, over each open set, of the distance from x to the outside of that open set, which is continuous by the triangle inequality.)
or if you want to stick closer to the author's proof, basically you want to show that if 0 < t1 < 1, and the lift of gamma is defined on every subinterval [0,t0] with t0<t1, then the lift can also be defined on [0,t1]. For that, choose an open set U containing t1, and evenly covered. Then for some t0<t1, the image under gamma of the interval [t0,t1] is contained in U, and the already defined lift on [0,t0] takes t0 into a unique component V of the preimage of U in X. Since V≈U, and gamma maps [t0,t1] in to U, it is easy to extend the lift of gamma mapping [t0,t1] into V, via [t0,t1]-->U-->V.
Thanks for all help! I think I got it!
  • · Replies 0 ·
  • · Replies 24 ·
