Question about Pi in different base
  • Thread starter Thread starter f24u7
    Base Pi
The discussion explores the relationship between pi (∏) in different numerical bases, emphasizing the importance of the DIV/MOD algorithm for converting integers into various bases. It highlights the use of sawtooth and trigonometric functions to calculate modulus, which is essential for understanding pi's representation in different bases. The conversation suggests that multiple definitions of pi can be applied depending on the chosen base and algorithm. Additionally, resources like the Bailey-Borwein-Plouffe Pi Algorithm are recommended for further exploration of pi's properties. Overall, the thread provides insights into mathematical concepts related to base conversions and pi.
f24u7
Hi, recently I have being thinking about math in different bases, and I was wondering if there is a relationship between ∏ from different bases.
Also is there mathematics related books that discusses math in different bases?
Thanks in advance
Mathematics news on Phys.org
Thanks in advance
Hey f24u7.
In terms of a general base you need to calculate the equivalent of a "MOD" function which is used to take an integer and decompose it into a certain base, but for any valid continuous base.
The algorithm to do this is known as the DIV/MOD algorithm.
What you do is you use either a sawtooth function to calculate the modulus, or you can use trigonometric functions. The sawtooth has the same interpretation and application as a normal MOD function that you do in normal number theory applications involving whole positive numbers.
Because you haven't given a base, you will need to use the DIV/MOD definition, use the sawtooth or a similar construction for calculating the "MOD" (or remainder part) and take it from there.
There are quite a few definitions for pi so depending on your problem, and the construction of the DIV/MOD algorithm, you can use the different definitions, your base, and the DIV/MOD formulation to get some particular expression.
The trigonometric functions are useful because of the relationship with pi itself and also with the relationship with MOD in indirect ways.
This may be of interest: The Miraculous Bailey-Borwein-Plouffe Pi Algorithm
http://www.andrews.edu/~calkins/physics/Miracle.pdf
Thank you very much for this: I found it immensely useful :)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 44 ·
  • · Replies 19 ·
28K
  • · Replies 34 ·
