Question of electricity net force
5 replies · 3K views
toesockshoe
Three point charges are located on the positive x-axis of a coordinate system. Charge q1 = 1.0 nC is 2.0 cm from the origin, charge q2 = -3.5 nC is 4.0 cm from the origin and charge q3 = 6.0 nC located at the origin. What is the net force ((a)magnitude and (b) direction) on charge q1 = 1.0 nCexerted by the other two charges?
The online homework grader is marknig my answer for part a wrong. Can someone tell me what's wrong with my solution for part a? My work is in the attachment.
2. Homework Equations
see attachment
[/B]
see the attachment for my solution. The online homework grader is saying my answer is wrong.
Check the locations of the individual charges. q3 is at the origin according the problem description. Your image has it off to the right.
It looks like you maybe placed the charges in the wrong spots? q3 is at the origin, q1 is at 2cm and q2 is at 4cm. So there is a repulsive force to the right from q3 on q1, and an attractive force to the right from q2 on q1...
EDIT: Rats, rats, rats, rats, rats! :cry:
if the pic isn't clear enough, here is a close up.
oh i fixed that. [tex]F_{q3q1}[/tex] should be 1.35x10^-4. The answer though is sitll wrong. I subtract the two forces because one pair is attractive while the other force is repulsive. The answer I get is 5.625x10^-5. The answer from homework grader gave me is 2.1x10^-4. This is what you would get if you add the two forces. Why would you add them?
gneill said:
What directions do the two force vectors point? Make a sketch.
oh yeah. i see the problem. thank you.
