Question on Elliptic Orbits. Difficult.
  • Thread starter Thread starter Wesc
    Orbits
The discussion revolves around solving a problem related to a satellite's elliptic orbit around Earth, focusing on deriving relationships for minimum and maximum velocities and eccentricity. Participants are attempting to use conservation of angular momentum and energy to find these values but express confusion about the next steps. The conversation highlights the need to apply the given equations of motion and the relationships between maximum and minimum distances to progress. Feedback emphasizes the importance of substituting known values into the equations to extract further information. Overall, the discussion seeks clarity on applying fundamental physics principles to solve the orbital mechanics problem.
Wesc
A satellite undergoes an elliptic orbit about the Earth of mass M, with maximum
distance 6R and minimum distance 3R from the Earth's centre.
(a) Show that twice the minimum velocity v(min) = the maximum velocity v(max) = (2/3)*sqrt(GM/R)
(b) Show eccentricity = 1/3
We are told that we can assume the orbit is described by 1/r = (1 + e*cos(Theta))/L where where r is the distance from the Earth’s centre, e is the eccentricity with 0 ≤ e < 1
and l = h^2/GM for constant h, the angular momentum per unit mass
How I started off was using the conservation of angular momentum and from that got v(max) = 2*v(min) . Tried conservation of energy but got nowhere there. Also tried other equations but I'm not getting anywhere! If anyone could show me a solution I would be so grateful :) Thank you.
Can you show exactly how conservation of energy got you nowhere?
For (b), what are the min/max values of the RHS of the equation of motion you were given?
Hey, thanks for the feedback.
Well for conservation of energy I did this:
E = (1/2)*m*v(max)^2 - G*M*m/r(min) = (1/2)*m*v(min)^2 - G*M*m/r(max)
I then canceled the 'm's .. and I'm not sure if you can really extract any other information from there??
And if you're talking about this equation of motion 1/r = (1 + e*cos(Theta))/L then the max is at cos(Theta) = 1 and min at cos(theta) = -1 but I'm just not sure what the next step is? I'm just a bit lost. :/
You have obtained the relationship between Vmax and Vmin, and you were given the relationship between Rmax and Rmin. Use them.
That is correct, plug that into the equation and use Rmax and Rmin.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
