Question on Importance Sampling (Monte Carlo method)
  • Level: Graduate
  • Thread starter kasraa
    Method Sampling
2 replies · 4K views · last reply
kasraa
Hi,
Suppose I have N iid samples from a distribution q, and I want to estimate another distributin, p, using those samples (Importance Sampling).
By "standard importance sampling", I mean the case where samples (prior samples. i.e. samples from q) have equal weights ([tex]w_i = 1/N[/tex]).
In the case of "standard importance sampling", I should perform these steps:
1) compute (unnormalized) weights for those sample according to [tex]p(s_i)/q(s_i)[/tex] ([tex]s_{i}[/tex] is the i'th sample from q)
2) normalize those weights
3) then an estimate of p would be this:
[tex]\hat{p} = \sum_{i=1}^N w_{i} \delta(i)[/tex]
(w_i are normalized weights computed at step 2. delta(i) is the Dirac delta function at s_i)
Now consider the case where samples (prior samples, i.e. samples from q) are weighted (different weights, and normalized. for example [tex]u_i[/tex]).
Is it enough (justified) to change the (unnormalized) weights (computed at step 1) to [tex]p(s_i)u_{i}/q(s_i)[/tex]?
(multiplying prior weights and "standard importance sampling" weights together?)
Thanks in advance.
kasraa said:
... Is it enough (justified) to change the (unnormalized) weights (computed at step 1) to [tex]p(s_i)u_{i}/q(s_i)[/tex]?
Possibly not, because any Monte Carlo simulation (including importance sampling) is essentially based on approximating the (cumulative) distribution by the empirical distribution, i.e.
[tex]P(x) = Prob[X\le x] = E_P[I[X\le x]] \approx \frac{1}{N}\sum_{i=1}^N I[X_i\le x][/tex]
where I is the Boolean indicator function and the [tex]X_i[/tex] are taken from distribution P. To change the weights from (1/N) to other numbers you'd need to change the sampling method to ensure that the "weighted" empirical distribution remains a good approximation to the CDF.
However if you do find a way to overcome that, the new importance sampling formula would easily follow from the change of measure formula, with
[tex]P(x) = E_P[I[X\le x]] = E_Q\left[I[X\le x]\frac{dP}{dQ}\right] = E_Q\left[I[X\le x]\frac{p(X)}{q(X)}\right] \approx \sum_{i=1}^N w_i I[X_i\le x]\frac{p(X_i)}{q(X_i)}[/tex]
where the [tex]X_i[/tex] are samples such that
[tex]\sum_{i=1}^N w_i I[X_i\le x][/tex]
closely approximates Q(x).
