Question on problem 7 on July Challenge
  • Level: Undergrad
  • Thread starter Thread starter BWV
    Challenge
12 replies · 2K views
BWV
TL;DR
Trying to follow and learn from the solution and did not want to clutter up the original thread
nuuskur said:
Fubini allows us to change order of integration, so we get
[tex] \mathbb EX = \mathbb E \left ( \int _0^t W_s^2ds\right ) = \int _0^t \mathbb E(W_s^2)ds = \int_0^t sds = \frac{t^2}{2}[/tex]
My naive question is why doesn't Jensen's Inequality prevent this step?
246277
Where you are swapping the expectation of a function for applying the function to the expectation which according to the inequality, the two expressions are equal only if the function is linear, which W^2 is not
BWV said:
Summary: Question on problem 7 on July Challenge
I don't really understand your question. What is ##\varphi## here? Is it ##\varphi(x) = x^2?##. In that case, Jenssen says that
$$E\left[\left(\int_0^t W_s^2 ds\right)^2\right]= E[X^2] \geq (EX)^2 = \left(\int_0^t W_s^2 ds\right)^2$$
and I don't see how that contradicts the statement you mention.
Math_QED said:
Are you sure this is correct? By definition, if XX is a random variable on a probability space (Ω,F,P)(Ω,F,P), then
E(Y):=∫ΩY(ω)P(dω)E(Y):=∫ΩY(ω)P(dω)​
Agreed, my initial post didn't make much sense at all. Post-edit it should be ok.
Math_QED said:
I don't really understand your question. What is φφ here?
My guess is he assumed I used Jensen's inequality to arrive at whatever I arrived at, the [itex]\varphi[/itex] is supposed to be a convex map, which one, I can't say.
Math_QED said:
Now it is correct, though I'm not sure if this integral exists if and only if ##\int_\Omega Y dP## exists. It is definitely true that if the expectation exists and is finite, then your integral exists and is equal to the expectation.
Right right. The equality holds precisely when [itex]Y[/itex] has a probability density function. My probability theory has several layers of rust on it by now :(
Now that I think about it, my previous reply was incorrect. Isn't the correct formula
##E(Y) = \int_{\mathbb{R}} yf_Y(y) dy##
where ##f_Y## is a density function of ##Y## (assuming it exists!). The formula you listed in post #3 can't be correct for the simple reason that ##Y(s)## with ##s \in \mathbb{R}## does not make sense because ##Y## is not necessarily defined on the real numbers. I suggest you edit the post with the correct definition ##EY = \int_\Omega Y dP## and then also the rest of the answer.
Indeed, using this definition
$$E(X) = \int_\Omega X dP = \int_\Omega \left(\int_0^t W_s^2 ds\right) dP = \int_0^t \left( \int_\Omega W_s^2 dP\right) ds = \int_0^t E[W_s^2] ds$$
and the third equality follows by Fubini.
Ok forget it then, thought I could learn something but too far outside my pay grade
Please do ask. I'm just trying to understand your confusion so I can give you my best answer :).
The question was basic - why doesn't Jensen apply when moving the expectation inside / outside of the integral?
Im sure my confusion stems from what is getting integrated over what -the 'function' here which is being moved is integrating over the variance (time)
Not sure how to interpret integrating X over t, have some experience with stoc calculus but its always derivatives of X as in Ito's Lemma
maybe the way to think of it is define ##g## by
##g(W_s)= W_s^2##
so ##g## is strictly convex but
##h_t(X) = \int_0^t X dx##
is linear -- i.e. homogenous with respect to scaling and additivity. Linear functions are convex and concave. So the problem is
##E\big[ h_t(g(W_s))\big]= h_t(E\big[g(W_s))\big]##
by linearity (subject to convergence considerations -- I'm fairly confident you could justify the interchange on dominated convergence as well )
what Jensen says is
## h_t\Big(E\big[g(W_s)\big]\Big) \gt h_t\Big(g(E\big[W_s\big])\Big)##
because ##g## is strictly convex (and ##W_s## isn't constant with probability 1)
or more simply, for any ##s \gt 0##
##E\big[g(W_s)\big] \gt g(E\big[W_s\big])##
then we sum or integrate over this point-wise bound to recover the above
Thanks - so because integration is linear, it meets an equality condition of Jensen & it can be moved in or outside of the expectation operator
if we don't worry too much about convergence issues then I suppose you can say this. The more basic idea is Linearity of Expectations. (Then bring up Jensen for functions that aren't linear/affine but are known to be convex or concave)
I'm told that Brownian motion is Riemann integrable, and in any case an important way to think about very complicated stuff is with countable sets when possible (not always possible but you should try) and then countable sets with finite ones wherever possible.
So write out the Riemann Integral which I assume exists
##S_n := \frac{1}{n}\sum_{i=1}^n g(W_{\frac{it}{n}}) \approx \int_{0}^t g(W_s) ds##
and by linearity of expectations, for any natural number ##n##, you always have
##E\big[S_n\big] = E\big[\frac{1}{n}\sum_{i=1}^n g(W_{\frac{it}{n}}) \big] = \frac{1}{n}\sum_{i=1}^n E\big[g(W_{\frac{it}{n}}) \big]##
(this always holds, irrespective of whether they are independent, something a lot of people stumble on.)
The convergence issue that can come up is that when you pass limits, in general
##\lim_{n \to \infty} E\big[X_n\big] \neq E\big[\lim_{n \to \infty} X_n\big]##
though dominated convergence can frequently be used to alleviate situations like this.
