Question on the Irreducibility of Polynomials
  • Topic:
  • Thread starter Thread starter Math Amateur
    Polynomials
1 reply · 2K views
Math Amateur
MHB
I am reading Dummit and Foote on Polynomial Rings. In particular I am seeking to understand Section 9.4 on Irreducibility Criteria.
Proposition 9 in Section 9.4 reads as follows:
Proposition 9. Let F be a field and let [tex]p(x) \in F[x][/tex]. Then p(x) has a factor of degree one if and only if p(x) has a root in F i.e. there is an [tex]\alpha \in F[/tex] with [tex]p( \alpha ) = 0[/tex]
Then D&F state that Proposition 9 gives a criterion for irreducibility for polynomials of small degree
D&F then state Proposition 10 as follows:
Proposition 10: A polynomial of degree two or three over a field F is reducible if and only if it has a root in FBUT! Here is my problem - why does not a root in F imply reducibility in polynomials of all degrees? A root in F means, I think, that the polynomial concerned has a linear factor and hence can be factored into a linear factor times a polynomial of degree n-1?
Can anyone clarify this for me?
Peter
[This question has also been posted on MHF]
You are right, but take into account that proposition 10 says if and only if. For example consider $F=\mathbb{R}$ and $p(x)=(x^2+1)(x^2+2)$. This polynomial is obviously reducible in $\mathbb{R} [x]$ and has no real roots.
