Question regarding binomial theorem.
5 replies · 2K views
sankalpmittal
(√2 + 1)6 = I + f
Where I is the sum of integer part of the expansion of (√2 + 1)6 and f is sum of the fraction part in (√2 + 1)6.
(x+1)n = nC0 xn + nC1 xn-1 + nC2 xn-2 + ... + nCn
nCn = nC0 = 1
I expanded (√2 + 1)6 , then simplified and then got the expression 44+99√2/2.
Then I got I=44 which was not even the correct answer. The correct was 197. This question is a competitive level question.
Thanks in advance... :smile:
Hi sankalp :smile:
The answer you get is incomplete. The second term also has an integral and fractional part itself. You need to add them to get your answer :wink:
Another way to see it is that f is defined to be between 0 and 1, so is your fractional part between zero and one?PS : Your expansion itself seems incorrect to me. Recheck it.
Infinitum said:
Hi sankalp :smile:
Hii Infinitum! :smile:
One way to do is to seriously find (√2 + 1)6. But that will be a noob way.
Ok , so on expanding , I get :
(√2 + 1)6 = 6C0 8 + 6C1 4√2 + 6C2 4 + 6C32√2 + 6C4 2 + 6C5 √2 + 6C6
Now on solving , I get (√2 + 1)6 = 99+ 70√2
I + f = 99+ 70√2
Now what else can I do ? Any hint ?
I + f = 99+ 70√2
Yep. That sounds correct. Now you can use the approximate value of √2 to multiply, and hence get the integral part of the expansion.
Hint : You only need to use 1.41 as your approximation, as any more digits will not change effect the integral part :wink:
Did not recognize that this was so simple...
99+ 70√2
99+ 70(1.41)
I = 99+98 = 197 !
Awesome! :smile:
Edit : All right , thanks for the efforts...
The method your professor uses can be applied in general to all such problems, so it is good in its own right. The one I suggest requires that you know the value of √2, which is frequently used and known. What about when it is √327? You would have to first find the square root, then approximate.
