Question regarding Earth, Moon and tidal forces
14 replies · 3K views · last reply
ezach1
If the distance between the Earth and the Moon doubled, by what factor would the tidal forces felt on Earth decrease by?
Not sure if there are any relevant equations
F = GM1M2 / r∧2
[/B]G = 1/d^2, if d is doubled, then G = 1/2^2 = 1/4 The force is 1/4 the original strength.
Im trying guys...
so the answer is right? but I was suppose to use the roche limit equation?
No, the answer was wrong, because you based it on the wrong formula, but the idea in your attempt is correct.
You will find the correct formula easily if you look for it in the internet (as well as the derivation).
Am I looking for the roche limit equation? or Newtons law?
stockzahn said:
Try "derivation of tidal forces" or "tidal force equation"
Ftidal= 2GMearth md/r^3
That would be the tidal force on the moon caused by the earth. Try to adapt it.
And just to be sure: what do r, d and m mean in your equation?
r is the radius of the moon, d is the distance, and m is the affected object on the moon??
swap Earth and moon??
With this logic the tidal forces would in increase with increasing distance and decrease with increasing size of the moon. Does that seem to be correct?
no...i guess back to the drawing board.
My head is about to explode...
Try to write down the formula for the tidal forces caused by the moon on Earth and use unambiguous symbols with correct indices and/or describe them properly.
I can't...but thanks for your time and help. It is much appreciated...
ezach1 said:
I can't...but thanks for your time and help. It is much appreciated...Im slowly realizing that I need help with basic math/algebra. Only then will I be able to understand these equations.
