Sequence of b_{k} with Explicit Formula: Proving by Math Induction
The discussion centers on the sequence defined by the recursive formula \( b_k = \frac{b_{k-1}}{2 + b_{k-1}} \) with the initial condition \( b_0 = 1 \). The explicit formula proposed is \( b_n = \frac{2}{n + 2} \), which is incorrect based on the calculations provided. The correct sequence converges to \( \{ 1, \frac{1}{3}, \frac{1}{7}, \frac{1}{15}, \ldots, \frac{1}{2^{n+1}-1} \} \) as derived from the recursive definition.
  • Understanding of recursive sequences and their definitions
  • Familiarity with mathematical induction techniques
  • Basic knowledge of algebraic manipulation and fractions
  • Experience with convergence of sequences
  • Study mathematical induction proofs in detail
  • Explore recursive sequences and their explicit forms
  • Learn about convergence criteria for sequences
  • Investigate the properties of series and their limits
Mathematicians, educators, and students interested in recursive sequences, mathematical induction, and convergence analysis will benefit from this discussion.
hkhgg
$$b_{k} = b_{k - 1}/2 +b_{k-1} $$
$$b_{0} = 1 $$
What would be the sequence for this expression, I calculated it to be 1, 2/3, 2/5, 2/7 ...
Is it right?
My explicit formula is $$b_{n} = 2/n+2 $$
What would be the explicit formula in your view and how can that formula be proved by mathematical induction? thanks
First, what is the formula defining the sequence? You wrote $b_k= b_{k-1}/2+ b_{k-1}$ but since that would be more simply written as $3b_{k-1}/2$ I wonder if you did not intend $b_k= \frac{b_{k-1}}{2+ b_{k-1}}$.
Assuming what you wrote was correct, since $b_0= 1$, $b_1= 1/2+ 1= 3/2$, $b_2= (3/2)/2+ (3/2)= 3/4+ 3/2=3/4+ 6/4=10/4=5/2$... That is not what you write so apparently that is not what you intend.
With $b_k= \frac{b_{k-1}}{2+b_{k-1}}$ and $b_0=1$, $b_1= \frac{1}{2+ 1}= \frac{2}{3}$, $b_2= \frac{\frac{2}{3}}{2+ \frac{2}{3}}= \frac{\frac{2}{3}}{\frac{6}{3}+ \frac{2}{3}}= \frac{\frac{2}{3}}{\frac{8}{3}}= \frac{2}{3}\frac{3}{8}= \frac{2}{8}= \frac{1}{4}$.
That is also not what you have so, no, you are not correct.
I can't respond to the rest of you questions because I do not know whether you intend $b_k= \frac{b_{k-1}}{2}+ b_k= \left(\frac{3}{2}\right)b_{k-1}$ or $b_k= \frac{b_{k-1}}{2+ b_{k-1}}$.
$b_k = \dfrac{b_{k-1}}{2+b_{k-1}}$
$\displaystyle \bigg\{ 1, \dfrac{1}{3}, \dfrac{1}{7}, \dfrac{1}{15}, … , \dfrac{1}{2^{n+1}-1} , … \bigg \}$
  • · Replies 16 ·
