Mentor
- 15,601
- 10,948
No. Superposition refers to a mathematical property of the wave function, namely that any wave function can be written as the sum of other wave functions.rede96 said:Is that what is meant when we say the electron is in a superposition?
From #23 of this thread: “we add the amplitudes of the waves arriving from all open points in the barrier”. That means “all open points” whether these points are all in one slit or in multiple slits.May I ask when calculating the probability of a single electron being detected are both slits included in the calculation?
You may have been confused by the way that elementary and non-serious explanations treat the double-slit case as something somehow fundamentally different from the single slit case. It’s not, it’s just the easiest example of interference. What’s going on here is that if two openings are small compared with the wavelength of the incident beam, and if they are separated by a distance that is large compared with that wavelength but are still close enough together to both be illuminated by the beam... then to very good approximation we can say that there are just two points and two amplitudes, one from each point, to add - @PeroK showed you that calculation in post #10.
But if these conditions do not hold, then the calculation requires adding the amplitudes from each point; there are an infinite number of points in any non-zero area no matter how small so we end up having to do a seriously non-trivial integration across the area of all the openings (one slit, two slits, twenty-three slits, the holes left by a volley of machine-gun fire, ...) in the barrier.
No pop-sci treatment is going to inflict this integral on the audience when a “just add two things” example is an option, so we miss out on the general principle. The introductory QM course for an undergraduate physics major is a different matter; we don’t start that until after we’ve spent an entire semester with something like this so we that we can do the general calculation for any configuration of the barrier.
That’s classical thinking. We’re using the classical idea that a particle can’t be at A and later at B without having been somewhere in between; without that assumption there’s no reason to think that the particle was ever anywhere near the barrier and slits.maybe it’s just my use of words or classical thinking. Can’t help but think if the slits effect the outcome then there is something going on with the electron and the slits, even if we don’t need to know what that is to calculate the probability of an electron being detected at a certain point on the screen. Not important for QM of course but can’t help but wonder what it could be. :)
