Questions about e=mc2 and probably other equations
  • Thread starter Thread starter AviiNL
    E=mc2
The discussion centers on the equation E=mc², specifically the units used for energy (E) when mass (m) is expressed in grams and speed (c) in meters per second. The correct unit for energy is Joules (kg·m²/s²), while other combinations like gram-meters squared per seconds squared do not have standard names. The participants emphasize the importance of using consistent units, recommending conversion to SI units (kilograms, meters, seconds) for clarity and accuracy in calculations.
  • Understanding of the equation E=mc²
  • Familiarity with SI units: kilograms (kg), meters (m), seconds (s)
  • Basic algebra for unit conversion
  • Knowledge of energy units, specifically Joules (J) and ergs
  • Research unit conversion methods for physics calculations
  • Learn about the significance of SI units in scientific equations
  • Explore the differences between CGS and MKS unit systems
  • Study the implications of E=mc² in various physics contexts
Students new to physics, educators teaching foundational physics concepts, and anyone interested in understanding energy calculations and unit conversions in scientific equations.
AviiNL
Hello,
So, I was wondering something about the units used with other units in a equation like e=mc2
For example;
m = 1.67x10^24 grams
c = 292.792.458 m/s
that makes e about 1.437x10^-8
but what is the unit used to represent e in this context?
and what if I used kg in m and km/s in c, what would the unit for e be then?
An explanation would be really appreciated.
Side note:
I just started to get an interest in physics like 2 weeks ago,
and never had any prior education in school or whatever about these sort of things.
nor had any education in maths used with most physics equations (algebra and stuff)
I really find it all very interesting, seen various coursed on youtube by Walter Lewin from MIT, and other channels like Sixty Symbols, veritasium1 and numberphile (and others)
Kind regards and thanks for reading,
AviiNL
AviiNL said:
Hello,
For example;
c = 292.792.458 m/s
Side note:
AviiNL
For one thing the equation is correctly written ##e=m c^2## or e=mc^2. And the value your for e given m and c is WAY OFF. Finally, kg*m^2/s^2 is a unit of energy called a Joule. Other combinations like g*m^2/s^2 or kg*km^2/s^2 don't have names. If you are given other units, I'd convert them to kg, m and s first.
AviiNL said:
Hello,
For example;
c = 292.792.458 m/s
Side note:
AviiNL
Not only do you multiply the numerical values, you also multiply the units just as though they were algebraic objects. So, c^2 has units m^2/s^2, hence E = m c^2 has units
kg m^2/sec^2; this is also called the Joule and is denoted as J. (Unfortunately, the symbol 'm' for mass is the same as 'm' for meter, and that can cause confusion; that is why sometimes we write out the word 'meter' or 'metre' in full.) Note that I used 'E' instead of 'e', because that is more usual in Physics (E = energy, e = magnitude of electron charge, or base of natural logarithms).
Stick to (or convert to) SI units:
kg for mass
m for distance
s for time
Then you find that all the equations give you the SI unit for whatever, and you can look that up on Wikipedia.
Dick said:
For one thing the equation is correctly written ##e=m c^2## or e=mc^2. And value your for e given m and c is WAY OFF. Finally, kg*m^2/s^2 is a unit of energy called a Joule. Other combinations like g*m^2/s^2 or kg*km^2/s^2 don't have names. If you are given other units, I'd convert them to kg, m and s first.
Wow,
That confused me even more just now.
What I get is; use Meters in combination with kilograms to get energy as Joules
What I don't get is; km^2/s^2, as km/s is a short representation of kilometers per second, right? 1 seconds squared would still be 1 right?
So, to calculate E with the numbers given above should be like
m = 1.67x10^-27 kg (i think?)
c = 292.792.458 m/s (is still meters per second)
then E = (1.67x10^-27)*(292,792,458^2) = 1.431x10^-10 J
Am I going the right way with this now?
Thanks for the replies :)
AviiNL said:
Wow,
The calculation looks right now. Yes, 1.67x10^(-24)g=1.67x10^(-27)kg. You didn't have the minus sign on the exponent in the original post. That's why I thought it was so far off.
Ah lol indeed, i forgot to put the minus sign in the first post, my bad :p
Thanks for clearing this up :)
Now I can sleep without this swarming through my brain lol :p
AviiNL said:
Wow,
Numerically, it's 1, but the units would be sec2.
Lewin's videos are for people who have already taken calculus so those may not be the best ones out there. You might just want to look for some conceptual videos.
Also I wouldn't start with trying to understand Einstein if you're completely new to physics. Go back to Newtonian physics and progress from there if you want a deeper understanding of physics.
The CGS unit of energy, 1 g*m^2/s^2 , is called an erg. For historical reasons, most astronomers and astrophysicists use ergs instead of Joules. 1 Joule = 10^7 ergs.
I actually find Lewings lectures quite easy to understand, and his lectures got me started in physics :)
But the reason for this thread was not to understand einsteins e=mc^2, but more about the actual maths behind it, and it actually got a lot more clear to me now :)
You may find it hard t comprehend units like "per second squared" but you can think of it like "per second per second."
If Chevrolet says their new Corvette goes 0 m/s to 20 m/s in 4 seconds, that is an acceleration of 5 meters per second per second or 5 meters per second squared. This is kind of irrelevant but I hope you get the meaning of some of these units.
An erg is 1 g*cm^2/s^2.
My mistake. Thanks for the correction.
AviiNL said:
Hello,
For example;
c = 292.792.458 m/s
You are going to confuse yourself as well as others if you "mix" numerical notations. The United States, England and about half of the world use "." to separate the integer part of the number from the fraction part and "," to separate groups of thousands. That is the notation you use in "m= 1.67 x10^24 grams". Most of Europe and the other half of the world reverse those. That is the notatation you use in "c= 292.792.458 m/s".
Use either
m= 1.67 x 10^24 grams
c= 292,792,458 m/s
or
m= 1,67 x 10^24 g
c= 292.792.458 m/s
But not both!
No, it doesn't. Without checking the actual arithmetic, m and c both has positive powers of 10 so their product cannot have a negative power of ten.
In this contex "gram-meters squared per seconds squared" which does not have a standard name because it mixes "MKS" and "gms" systems. (You keep doing that!)[/quote]
That would make more sense. You are now working completely in the "MKS" (meter-kilogram-second) system. Then e would be in "kilogram-meters squared per second squared" which is called "Joules".
If you measured mass in grams and speed in centimeters per second, you would be working in the "cgs" (centimeter-gram-second) system. Then e would be in "gram-centimeters squared per second squared" which is called "ergs".
Side note:
AviiNL
  • · Replies 18 ·
14K
