Questions about operators and commutators
The discussion revolves around the commutation relation between the momentum operator P and a function g(r), specifically examining the expression [P, g(r)] = -iħ dg/dr. Participants clarify that to validate this equation, one must apply both sides to the same wavefunction, ψ(r), and check if the results match. It is noted that the left-hand side expands to Pg(r) - g(r)P, and the gradient operator acts differently depending on its position relative to g(r) and ψ(r). The conversation also touches on proving a similar expression involving g(P) and the position operator r, suggesting that calculations in momentum space could simplify the analysis. Overall, the discussion emphasizes the importance of operator placement and the application of commutation relations in quantum mechanics.
maverick_76
so I have an expression here:
[P,g(r)]= -ih dg/dr
P is the momentum operator working on a function g(r).
Is this true because when you expand the left hand side the expression g(r)P is zero because the del operator has nothing to work on?
The equation you have here is an equation between two different operators.
On the one hand that commutator, and on the other hand, that derivative.
In order to test this equation, you need to act the left and right hand sides on the same wavefunction, say \psi(r).
If you find that [P,g(r)]\psi(r) = -i\hbar \frac{dg}{dr}\psi(r), no matter what \psi(r) is,
then the operators must be equal as well.
Likes maverick_76 and Greg Bernhardt
Maybe I'm missing something here, because my limited knowledge of commutators says that the left hand side unpacked is
{ Pg(r)-g(r)P } Ψ(r)
I'm not sure how to show that
g(r)iħ dΨ/dr = 0 in order for the expression above to hold true.
The expression above is not equal to zero because:
when the momentum operator P is before both g(r) and \psi(r), that gradient acts on the product g(r)\psi(r) (and the product rule comes into affect), so you get one more term than you'd get otherwise when you compute the gradient. Indeed, that extra term is the same as what's on the right hand side of the equation:
(Pg(r) - g(r) P)\psi(r) = -i\hbar \frac{dg}{dr}\psi(r)
When the momentum operator P is after g(r), then the gradient inside P just acts on \psi(r).
Likes maverick_76
Ah I see now. So now how would I go about proving this expression:
[g(P), r] = -iħ dg/dP
I'm not sure how the del operator works inside a function.
My thoughts are g(P) unpacks as such:
-iħ∇(p) (the partial derivative with respect to P)
so g(P)r would be:
-iħdg/dP
I mean using the logic from the previous solution this allows for the second expression to hold true. Not sure if I'm following the math rules though...
There's probably many ways to deal with a situation like this, but I think the easiest would be to do the calculation in momentum space, so that g(p) is just a function of the variable p , while x is then expressed as the operator i\hbar\frac{d}{dp}. Then the problem can be solved in the same way as before.
  • · Replies 17 ·
