Questions about proof of the division article.
Dafe
(Thread should be named: Question about proof of the division algorithm, sorry about that)
Hi,
I am reading this proof of the division article:
http://xmlearning.maths.ed.ac.uk/lecture_notes/polynomials/division_algorithm/division_algorithm.php"
I will write some of it here in case you don't want to click on any links.
Theorem: Let [tex]f,g \in R[X][/tex] be polynomials with [tex]g \neq[/tex].
Then there exist unique polynomials [tex]q,r \in R[X][/tex] such that [tex]f=gq+r[/tex] and [tex]deg(r)<deg(g)[/tex].
Proof: We first prove existence of [tex]q,r[/tex].
If [tex]deg(g)>deg(f)[/tex] then we set [tex]q=0[/tex] and [tex]r=f[/tex].
Otherwise, [tex]deg(f) \geq deg(g)[/tex]
Let,
[tex]f=a_0+...+a_mX^m[/tex] where [tex]a_m \neq 0[/tex].
and
[tex]g=b_0+...+b_nX^n[/tex] where [tex]b_n \neq 0[/tex].
Define the integer [tex]d=m-n \geq 0[/tex]. We will use induction in [tex]d[/tex].
Base step: Let [tex]d=0[/tex], then [tex]m=n[/tex]. We set [tex]q=\frac{a_m}{b_m}[/tex].
I will stop there.
How come they set [tex]q=\frac{a_m}{b_m}[/tex]?
Since [tex]f(x)=q(x)g(x)+r(x)[/tex] isn't then
[tex]q(x)=\frac{f(x)}{g(x)} - \frac{r(x)}{g(x)}[/tex] ?
Thank you for your time.
Hi,
Let,
and
I will stop there.
In this "base case", d= 0, the two polynomials have the same degree and so their quotient is a number, not a function of x. For example, if [itex]f(x)= ax^2+ bx+ c[/itex] and [itex]g(x)= ex^2+ fx+ g[/itex] then
[tex]\frac{ax^2+ bx+ c}{ex^2+ fx+ g}[/tex]
is just the number a/e with a first degree remainder.
Thank you :blushing:
One more question (kind of the same):
The article goes on with the induction step:
Now we assume that this is true whenever [tex]d<k[/tex] and let [tex]d=k[/tex], so that
[tex]m=n+k[/tex]. Let [tex]f_1=f-(\frac{a_m}{b_n}x^{m-n}g)[/tex].
I do not understand this last step.
Since [tex]\frac{a_m}{b_n}x^{m-n}[/tex] would be the first step of long division, does [tex]f_1[/tex] somehow refer to this?
Feeling quite stupid here. Good thing it's Christmas soon, will drown my sorrows in food and drink.
Thanks again!
