Questions about solvable Lie algebras
The discussion revolves around solvable Lie algebras, specifically addressing propositions related to their properties as stated in J. E. Humphreys' "Introduction to Lie Algebras and Representation Theory." Participants seek clarification on proofs and examples related to the solvability of Lie algebras and their ideals, including the implications of certain properties and definitions.
  • One participant requests clarification on how to prove that a Lie algebra ##L## is solvable given that ##I## is a solvable ideal of ##L## and ##L/I## is also solvable.
  • Another participant provides a proof outline for the proposition, discussing the implications of the definitions of solvability and the structure of the quotient ##L/I##.
  • Examples involving upper triangular matrices are proposed to illustrate the concepts of solvable ideals and their quotients.
  • Participants discuss the relationship between the solvability of a Lie algebra and its homomorphic images, noting that if a homomorphic image is solvable, it does not necessarily imply that the original algebra is solvable.
  • There are requests for further examples to clarify the propositions, particularly regarding the implications of solvability in different contexts.
Participants express varying degrees of understanding and seek further clarification on specific proofs and examples. There is no consensus on the best approach to proving the propositions, and multiple viewpoints on the implications of solvability are presented.
Some participants note the need for examples to illustrate the theoretical propositions, indicating that the discussion may be limited by the abstract nature of the concepts involved. There are also references to specific mathematical steps and definitions that remain unresolved.
HDB1
TL;DR
About solvable algebra
Please, in the book of Introduction to Lie Algebras and Representation Theory J. E. Humphreys p.11, I have a question:
Proposition.
Let ##L## be a Lie algebra.
(a) If ##L## is solvable, then so are all subalgebras and homomorphic images of ##L##.
(b) If ##I## is a solvable ideal of ##L## such that ##L / I## is solvable, then ##L## itself is solvable.
(c) If ##I, J## are solvable ideals of ##L##, then so is ##I+J##.
Please, in proof, (b); how we get:
##\left(L^{(i)}\right)^{(j)}=L^{(i+j)} \text { implies that } L^{(n+m)}=0##
Thanks in advance,
Dear, @fresh_42 , if you could help, I would appreciate it. :heart:
HDB1 said:
TL;DR Summary: About solvable algebra
Proposition.
Thanks in advance,
You can formally prove ##\left(L^{(i)}\right)^{(j)}=L^{(i+j)}## by induction. However, the heuristic should be sufficient to convince you. What is ##L^{(i)}##? It is ##L## multiplied by itself, then the result multiplied with itself, then this result multiplied with itself and so on, ## i ## times. The same is then done with that result another ## j ## times. But this is the same as starting with ##L## and proceeding ## i+j ## times.
In part (b) of the proof we have that ##I## is solvable and ##L/I## is solvable. The first means ##I^{(n)}=0## for some ##n## and the second means ##\left(L/I\right)^{(m)}=0.##
Now we must look at the definition of the quotient (see the other thread) and remember what the zero in ##L/I## is. It is the equivalence class ##0 + I## which is ##I##. Hence solvability of ##L/I## means that ##\left(L/I\right)^{(m)} \subseteq 0+I=I.## The multiplication in ##L/I## goes
[a+I\, , \,b+I]=[a\, , \,b]\, +\,I
Combining all that we have ##\underbrace{\left(\underbrace{\left(L/I\right)^{(m)}}_{\subseteq I}\right)^{(n)} }_{\subseteq I^{(n)}=\{0\}}.##
  • Love
Thank you so much, @fresh_42 , :heart:
But, please, how then prove that ##L## is solvable?
##L/I## is solvable. That means multiplying it with itself and so on will end up as ##\bar 0.##
But the ##\bar 0## class in the quotient ##L/I## is ##0+I=I.## So we end up in ##I## after sufficiently many steps. Now, ##I## is also solvable, too. So we proceed with multiplying everything with itself and after another ##n## steps we will be in the real ##\{0\}## subset of ##L, ## i.e. at ##0\in L.## That makes ##L## solvable.
Proposition.
Thanks in advance,
Dear, @fresh_42 , I am so sorry, but I have a question here:
about: (b), I need example of it, and I found: upper triangular matrix, let it ##A##, so if we bracket ##A## with itself, we will get strictly upper matrix, which is nilpotent, and then: solvable ideal, but what about the quotient of upper with strictly? what will be the outcome, please,
also please, do you have example of (a) or (c)..
Thanks in advance, :heart: :heart: :heart:
Let's take ##n=4## in your example, i.e. the Lie algebra of upper ##4\times 4## triangular matrices, and its ideal ##I## of strictly upper ##4\times 4## triangular matrices.
\left\{\begin{pmatrix}0&x_{12}&x_{13}&x_{14}\\0&0&x_{23}&x_{24}\\0&0&0&x_{34}\\0&0&0&0\end{pmatrix}\right\} = I \trianglelefteq L = \left\{\begin{pmatrix}x_{11}&x_{12}&x_{13}&x_{14}\\0&x_{22}&x_{23}&x_{24}\\0&0&x_{33}&x_{34}\\0&0&0&x_{44}\end{pmatrix}\right\}
Every element in ##L## can be written as ##X=D+S## where ##D## is a diagonal matrix, and ##S\in I.## You correctly noted that a) ##I## is a nilpotent, and therewith solvable ideal in the solvable algebra ##L.##
a) ##I\trianglelefteq L\;:##
[X,T]=[D+S,T]=\underbrace{[D,T]}_{\in I}+\underbrace{[S,T]}_{\in [I,I]\subseteq I} \text{ for any } X=D+S\in L\, , \,S,T\in I
b) ##I^3=[I,[I,[I,I]]]=\{0\}\,:##
Let ##e_{pq}## be the matrix with a ##1## in position ##(i,j)## i.e. ## i ##-th row and ##j## th column and zeros elsewhere. Then ##[e_{12},[e_{12},[e_{12}+e_{23},e_{23}+e_{34}]]] = [e_{12},[e_{12},e_{13}+e_{24}]]=[e_{12},e_{14}]=0## is the longest expression we can get.
c) ##I^{(2)}=\{0\}\,:##
\left[\begin{pmatrix}0&x_{12}&x_{13}&x_{14}\\0&0&x_{23}&x_{24}\\0&0&0&x_{34}\\0&0&0&0\end{pmatrix},\begin{pmatrix}0&y_{12}&y_{13}&y_{14}\\0&0&y_{23}&y_{24}\\0&0&0&y_{34}\\0&0&0&0\end{pmatrix}\right]=\begin{pmatrix}0&0&z_{13}&z_{14}\\0&0&0&z_{24}\\0&0&0&0\\0&0&0&0\end{pmatrix}
which is abelian, so ##[[I,I],[I,I]]=\{0\}.## I haven't calculated the values for ##z_{ij}## as we are only interested in the shape of the matric, not its values.
d) ##L/I \cong \left\{\begin{pmatrix}x_{11}&0&0&0\\0&x_{22}&0&0\\0&0&x_{33}&0\\0&0&0&x_{44}\end{pmatrix}\right\}## is abelian because ##[L,L]\ni [D+S,D'+S']=\underbrace{[D,D']}_{=0}+\underbrace{[D,S'] +[S,D']+[S,S']}_{\in I}.##
Note that ##I## is the zero in ##L/I## so ##L/I## is abelian, and therefore nilpotent, and therefore solvable.
e) Putting all these together we have:
[L,L] \subseteq I \,\Longrightarrow\, \underbrace{[\underbrace{[\underbrace{[L,L]}_{\subseteq I},\underbrace{[L,L]}_{\subseteq I}]}_{\subseteq [I,I]},\underbrace{[\underbrace{[L,L]}_{\subseteq I},\underbrace{[L,L]}_{\subseteq I}]}_{\subseteq [I,I]}]}_{\subseteq [[I,I],[I,I]]=\{0\}}
The idea behind (b) of the theorem is the following: We can write an element ##X\in L## as a sum of an element ##\bar X\in L/I## and ##S\in I.## ##\bar X## is the diagonal matrix ##D## I began with. Thus
[L,L]=[L/I + I\, , \,L/I +I]=\underbrace{[L/I,L/I]}_{\subseteq L/I} + \underbrace{[L/I,I]+[I,I]}_{\subseteq I}
Since ##L/I ## is solvable, continued multiplication by itself will end up in zero, which is ##I##. But then we are left with an expression that is completely in ##I.## However, ##I## is solvable, too, so continued multiplication by itself will end up in ##\{0\}.##
I'm not quite sure if this answers your question. If we take a higher value of ##n## then only the chains get longer, but the result will be the same. If we take ##n=2## or ##n=3## then the chains are shorter.
(a) is given by the definition of a Lie algebra homomorphism. Say we have ##\varphi \, : \,L\longrightarrow \varphi (L).## Then
[\varphi (L),\varphi (L)]=\varphi ([L,L]) \; , \;[[\varphi (L),\varphi (L)],[\varphi (L),\varphi (L)]]=\varphi ([L,L],[L,L])
and so on. If the chain of ##L's## becomes zero, so will the chain of ##\varphi (L)'s.##
Note that the opposite is not true. If a homomorphic image is solvable, i.e. ##(\varphi(L))^{(n)}=0## then we can only conclude that ##L^{(n)} \subseteq \ker \varphi ## which is in general not zero. In such a case we need the additional condition that ##\ker \varphi =\{0\},## i.e. that ##\varphi ## is injective, or at least that ##\ker \varphi ## is solvable, too.
You can take ##\varphi =\operatorname{ad}## as an important example and check it on the two-dimensional Lie algebra with ##[H,E]=2E## as multiplication.
Subalgebras are even easier. If ##U\subseteq L## then ##[U,U]\subseteq [L,L]## and so on. If the ##L's## becomes zero, so will any subalgebra ##U \trianglelefteq L.##
An example for (c) is the same as we used for (b). Take the diagonal matrices as ##J## and the strictly upper triangular matrices as ##I.## Both are solvable and so is their sum ##L.##
Edit: The diagonal matrices are only a subalgebra. If you insist on ideals, then take only those diagonal matrices that have the same value ##x_{11}=x_{22}=x_{33}=x_{44}.##
  • · Replies 19 ·
  • · Replies 19 ·
