Queueing Theory (M/M/1 with priorities)
  • Thread starter Thread starter TaPaKaH
    Theory
The discussion revolves around a queueing theory problem involving two types of customers with exponentially distributed interarrival and service times. The scenario includes a single server that prioritizes type 1 customers over type 2 customers. Participants are tasked with computing the fraction of time when there are no type 1 customers present in the server and queue, given that there is exactly one type 2 customer in the system.
  • Mixed
  • Participants explore balance equations related to the number of type 1 customers and discuss the challenges of conditioning on the presence of type 2 customers. There are attempts to analyze the system using transition diagrams and Markov chains, with some questioning the implications of different observation periods for the balance equations.
Several participants have shared their attempts at formulating balance equations and transition diagrams, indicating a collaborative exploration of the problem. There is recognition of the complexity involved in explicitly solving the system of equations, with suggestions for alternative methods such as multi-dimensional generating functions and analyzing the system from the perspective of type 2 customers.
Participants note the importance of considering the contributions of type 2 customers to the overall system stability, particularly in scenarios where the arrival and service rates suggest potential instability. There is also mention of imposed homework rules requiring participants to show their work and reasoning.
TaPaKaH
Suppose we have two types of customers, whose interarrival times are exponentially distributed with parameters ##\lambda_1## and ##\lambda_2##.
These customers have to share one server that gives preemptive priority to customers of type 1.
The service times are exponentially distributed with parameters ##\mu_1## and ##\mu_2##.
How can one compute the fraction of time, during which there are no type 1 customers in server+queue given that there is exactly one type 2 customer in server+queue?
I tried to approach the problem via balance equations for the number of type 1 customers, but couldn't figure out a way to implement "having exactly one type 2 customer" into the transition rates.
You need to show your work: what are the balance equations you tried to use?
The unconditioned number of type 1 customers in the system is a Markov chain with the following transition rates:
This yields balance equations ##p_n=\left(\frac{\lambda_1}{\mu_1}\right)p_{n-1}## that are easy to solve.
But, when we condition on there being exactly one type 2 customer, the "observation periods" have different lengths (which is ~##exp(\lambda_2)## for ##p_n,n\in\mathbb{N}## until another customer of type 2 arrives and ~##exp(\lambda_2+\mu_2)## for ##p_0## until either another type 2 customer arrives or current type 2 customer goes through their service) and might not start at "random times", which is causing me problems.
This transition diagram does not include any type-2 customers. I think you need a 2-dimensional diagram with nodes of the form (i,j), i = number of type 2 present and j = number of type 1. You have drawn the diagram for the first "row" (0,j), j = 0,1,2, ... .
Two-dimensional diagram is what I initially started with but it eventually reduced to this, which I thought might be "easier" to solve.
"Easier" ≠ "correct". The type-2 customers make an important contribution to the system: for example, if ##\lambda_2 / \mu_2 > 1## the system will be unstable (having no finite steady-state distribution) even though the type-1 queue might be stable, with ##\lambda_1 / \mu_2 < 1##.
Just to clarify: assuming a stable system and states of the form (i,j), where i = number of type-2 customers present in the system, and j = number of type-1, the two-dimensional transitition diagram can be analyzed using principles of balance, to conclude that the quantities
[tex]p_j = \sum_{i=0}^{\infty} \pi_{i,j}[/tex]
do, indeed satisfy ##\lambda_1 p_j = \mu_1 p_{j+1}##, giving ##p_0 = 1/(1-\rho_1)## and ##p_j = {\rho_1}^j\, p_0, \; j = 1, 2, \ldots .## Here, ##p_j## is the equilibrium probability that there are ##j## type-1 customers present in the system (in queue + in service). However, in terms of the 2-dimensional state space (i,j), you are asked to compute ##P(j=0|i=1)##.
Well, the global balance equations system is as follows$$\begin{cases}\begin{array}{rl}(\lambda_1+\lambda_2)p_{0,0}=\mu_2p_{0,1}+\mu_1p_{1,0}\\(\lambda_1+\lambda_2+\mu_1)p_{i,0}=\lambda_1p_{i-1,0}+\mu_1p_{i+1,0}&i\in\mathbb{N}\\(\lambda_1+\lambda_2+\mu_2)p_{0,j}=\lambda_2p_{0,j-1}+\mu_2p_{0,j+1}+\mu_1p_{1,j}&j\in\mathbb{N}\\(\lambda_1+\lambda_2+\mu_1)p_{i,j}=\lambda_1p_{i-1,j}+\lambda_2p_{i,j-1}+\mu_1p_{i+1,j}&(i,j)\in\mathbb{N}^2\end{array}\end{cases}$$In addition, we have the normalisation ##\sum_{i,j=0}^\infty p_{i,j}=1## and from analysis of queue 1 that doesn't "see" queue 2 we have ##\sum_{j=0}^\infty p_{i,j}=\left(1-\frac{\lambda_1}{\mu_1}\right)\left(\frac{\lambda_1}{\mu_1}\right)^i## for ##i\in\mathbb{N}_0##.
But I still can't see how this whole system could be explicitly solved to obtain ##p_{i,j}## and ##p_{0,1}## in particular.
This is not an easy problem. Perhaps you can try to use multi-dimensional generating function methods, in which you use the balance equations to obtain the mgf
[tex]M(u,v) = \sum_{i=0}^{\infty} \sum_{j=0}^{\infty} p_{i,j} u^i v^j[/tex]
You can look at this as either
[tex]M(u,v) = \sum_{i=0}^{\infty} B_i(v) u^i, \text{ where } <br /> B_i(v) = \sum_{j=0}^{\infty} p_{i,j} v^j[/tex]
or as
[tex]M(u,v) = \sum_{j=0}^{\infty} A_j(u) v^j, \text{ where }<br /> A_j(u) = \sum_{i=0}^{\infty} p_{i,j} u^i[/tex]
The balance equations might yield a solution for M(u,v) in terms of some undetermined constants, which could then be determined by using auxiliary information about system stability, etc. It might work; try it and see.
Another approach you might try is to look at the system from the point of view of type-2 customers. They see an M/M/1 queue with server 'vacations'. Vacations are periods during which the server is unavailable = times when it is serving customers of type-1. However, unlike many vacational queueing models, this one let's the server abandon service (to start a vacation) during the service of a customer (if a type-1 arrival kicks out the type-2 customer); most vacational queueing models allow the current service to be completed before the server goes on vacation. Anyway, the length of a server vacation is equal to the busy period of the M/M/1 queue for type-1 customers; this random variable (busy period length) has a complicated, non-exponential distribution involving Bessel functions, although its Laplace transform is not too bad.
Another, related approach is to note that the service time of a type-2 customer will be some very complicated thing consisting of a sum of iid exponentials and a random number of iid type-1 busy periods. (This corresponds to a number if iid exponential attempts, plus a number of type-1 busy periods during our poor type-2 customer is told to go and wait.) I think it might be possible to get the Laplace transform of the type-2 customer service time, and if so, the problem for type-2 customers becomes a simple M/G/1 queue with a horribly complicated service time distribution. However, getting from there to anything like a distribution of the number of type-2 customers present still seems difficult.
I tried the second approach: the busy period ##BP## for type-1 customers has the following Laplace-Stieltjes transform: ##\tilde{BP}(s)=\frac{\lambda_1+\mu_1+s-\sqrt{(\lambda_1+\mu_1+s)^2-4\lambda_1\mu_1}}{2\lambda}## so we can indeed model the type-2 queue as a queue, in which server uptimes are i.i.d. ~##\exp(\lambda_1)## and downtimes have LST above. However, this didn't yield any progress as computing type-2 distribution was too technically difficult.
I will try the first approach you suggested and see what comes out of it.
I found the following (free) paper that does all this:
http://arxiv.org/ftp/arxiv/papers/0902/0902.2086.pdf
It uses the 2-dimensional state space and finds the bivariate mgf. I have not checked it for correctness.
Note added in edit: I checked more carefully, and see that the above paper assumes ##\mu_1 = \mu_2##, although ##\lambda_1, \lambda_2## may differ. Also: the priority is non-preemptive. So, the your case has still not been done, but the paper perhaps points out a way of getting started, and the types of arguments that may be involved.
  • · Replies 0 ·
  • · Replies 18 ·
