Quotient space properties when dim Y equals dim X
2 replies · 2K views
Eclair_de_XII
Let ##X## be a vector space and ##Y## a subspace with ##\dim Y = \dim X##. Prove that ##Y=X##.
Quotient space of X mod Y:
##X/Y=\{x_1,x_2\in X:\,x_1-x_2\in Y\}##
Equivalence class of x w.r.t. quotient space:
##\{x\}_Y=\{x_0\in X:\,x_0-x\in Y\}\subset X/Y##
Theorem:
##\dim Y + \dim {X/Y} = \dim X##
Assume that ##X/Y## is defined. Since ##\dim Y = \dim X##, it follows that ##\dim {X/Y}=0## and that ##X/Y=\{0\}##.
Suppose that ##Y## is a proper subspace of ##X##. Then there is an ##x\in X## such that ##x\notin Y##.
Let us consider the equivalence class:
##\{x\}_Y=\{x_0\in X:\,x_0-x\in Y\}##
This is a subset of ##X/Y=\{0\}##, which means that because ##\{x\}_Y## is a vector space, ##\{0\}\subset \{x\}_Y##. Hence, ##\{x\}_Y=\{0\}##.
This implies that ##0-x\in Y## and that ##x\in Y##, since ##Y## is closed under scalar multiplication. This contradicts the fact that ##x\notin Y##.
Hence, there cannot be an ##x\in X## that is not in ##Y##. Thus, ##X=Y##.
I am a bit worried about the existence of ##X/Y##. Is it defined for every vector space? I am also worried that I am misinterpreting the meaning of quotient spaces and equivalence classes.
It's a bit complicated but correct. You have a subspace ##Y\subseteq X##. Then you can choose a basis ##\{x_1,\ldots,x_m,x_{m+1},\ldots,x_n\}## where ##m=\dim Y## and ##n=\dim X##. With ##m=n## you get ##X=Y##. But of course, this is proven along the lines of quotient spaces. As often, the essential point is: what are you allowed to use?
Eclair_de_XII said:
I am a bit worried about the existence of ##X/Y.## Is it defined for every vector space?
For every vector space ##X## and every subspace ##Y##. It only requires that ##Y## is a linear space.
No. You were right. As mentioned above: the easy way with bases is proven by the fact - and now comes the real reason why your proof works: every short exact sequence ##Y\rightarrowtail X \twoheadrightarrow X/Y## in the category of vector spaces splits, i.e. there is a monomorphism ##X/Y \rightarrowtail X## such that the composition of these homomorphisms is the identity on ##X/Y##.
This is not true in the category of groups, but it is for vector spaces. It simply means that ##x_{m+1}+Y,\ldots,x_n+Y## is a basis of ##X/Y## with the basis as described above.
Everything before page twenty-five of Linear Algebra and its Applications by Peter Lax. And this includes that theorem I cited. And I did learn about linear independence, span, bases, sums of vector spaces, theorems pertaining to those sums, quotient spaces, and equivalence classes that partition those spaces. Oh, and that theorem I cited.
Does that proof go something like:
Let ##S_X=x_1,...,x_n## be a basis for ##X## and ##S_Y=y_1,..,y_n## be a basis for ##Y##.
Suppose ##S_Y## does not span ##X##. Then there is ##x_i## that cannot be written as a linear combination of the vectors in ##S_Y##.
Hence, the sequence ##x_i,y_1,...,y_n## is linearly independent.
Suppose it spans ##X##. Then it is a basis of ##X## of length ##n+1##. This contradicts the fact that every basis of ##X## must have exactly ##n## elements.
If it does not, continue checking the vectors of ##S_X## until we have a basis for ##X## of length at least ##n+2## and at most ##2n>n##.
Either way, this is a contradiction. ##S_Y## must span ##X## as a result.
