Radial Force on Railway Engine of 120 Tons at 25mph
The discussion focuses on calculating the radial force acting on a railway engine weighing 120 tons traveling at 25 mph around a curve with a radius of 220 yards. The radial force is determined using the formula F = mv²/r, resulting in a force of 244.44 tons, which is then converted to weight by dividing by the acceleration due to gravity (32 ft/s²), yielding 7.638 tons. Additionally, the angle of banking for the outer rail is derived from the relationship between the radial force and the weight of the engine, leading to the equations Fcos(θ) = mg and Fsin(θ) = mv²/r for further calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with circular motion dynamics
  • Knowledge of trigonometric functions and their applications
  • Basic grasp of unit conversions in physics
  • Study the derivation of centripetal force in circular motion
  • Learn about the effects of banking angles on railway curves
  • Explore the application of trigonometric identities in physics problems
  • Investigate the impact of speed and mass on radial forces in engineering contexts
Engineers, physicists, and railway design professionals seeking to understand the dynamics of railway engines on curved tracks and the calculations involved in determining radial forces and banking angles.
John O' Meara
A railway engine of mass 120 tons travels round a curve of radius 220 yards at a speed of 25 miles per hour. Find in tons weight the radial force acting on the engine. If the resultant of the radial force and the weight of the engine acts in a direction normal to the plane of the track, and the gauge is 56.5 ins. how must the outer rail be banked up above the level of the inner rail.
66mph=88 ft/s, =>25mph=36.63 ft/s. F=ma = mv^2/r, F=244.44 tons, F= 244.44 divided by 32ft/s/s = 7.638 tons wt. where F= radial force.
Question: why divide by 32ft/s/s, I thought you multiplied the mass by the acceleration due to gravity to get the weight.
2nd part: first find the angle "theta" with which the resultant R is inclined to the vertical.
tan(theta) = 7.64/120 which give the wrong answer for theta: because 56.5"sin(theta) doesn't give you 3.6inches.Thanks guys.
I'm too lazy to make unit transformations. What I've understood from your post, this should solve the problem analitically:
[tex]Fcos(\theta) = mg[/tex]
[tex]Fsin(\theta) = mv^2/r[/tex]
[tex]\frac{v^2/r}{g} = tan(\theta)[/tex]
[tex]atan(\frac{v^2/r}{g}) = \theta[/tex]
[tex](gauge)sin(\theta) = (height)[/tex]
15K
17K
  • · Replies 19 ·
50K
  • · Replies 75 ·
