Radiation from an infinite current sheet
The discussion centers on the analysis of radiation from an infinite current sheet as presented in "The Feynman Lectures on Physics" (New Millennium Edition) by Feynman, Leighton, and Sands, specifically in section "18-4 A traveling field." The participants conclude that Feynman's assertion of a constant electric field (E field) and magnetic field (B field) after the wave front passes is correct, despite previous claims disputing this. The problem is also addressed in "Introduction to Electrodynamics" by David J. Griffiths, where the results align with Feynman's findings. The conversation highlights the importance of the continuity equation in validating the theoretical framework of the solution.
  • Understanding of Maxwell's equations and their implications.
  • Familiarity with electromagnetic theory, particularly in the context of current sheets.
  • Knowledge of the Poynting vector and its significance in energy flux analysis.
  • Experience with retarded Green's functions in electrodynamics.
  • Study the continuity equation in the context of electromagnetic theory.
  • Examine the derivation and implications of the Poynting vector in electromagnetic fields.
  • Review the use of retarded Green's functions in solving Maxwell's equations.
  • Analyze the differences between transient and steady-state electromagnetic fields.
This discussion is beneficial for physicists, electrical engineers, and students of electromagnetism who are exploring advanced concepts in electromagnetic radiation and current distributions.
scoomer
The Feynman LECTURES ON PHYSICS (NEW MILLENNIUM EDITION) by FEYNMAN•LEIGHTON•SANDS
VOLUME II discusses radiation from an infinite sheet of switched-on constant current in section "18-4 A traveling field" on page 18-15. The solution shows a constant E field and constant B field at a given point x after the wave front has passed x. The constant E field as been disputed.
A now closed PF discussion found at "https://www.physicsforums.com/threads/infinite-current-sheet-current-suddenly-turned-on.419209/" makes claims that there is no steady E field and thus Feynman is in error.
This same scenario is given as a problem in "Griffiths, David J. (2007), Introduction to Electrodynamics,. 3rd Edition; Pearson Education - Chapter 11, problem 24" and the solution is given at
"physicspages.com/pdf/Griffiths%20EM/Griffiths%20Problems%2011.24.pdf"
in Example 1 on page 4 which for the case a steady current. The result in this article agrees with Feynman's result of a constant E field.
Is Feynman right or wrong? I believe that Feynman is correct (although there isn't much discussion about the resulting E field). Can anyone comment on which answer is correct?
Thank you TSny! Previously, I misread the responses. I now see they all agree that Feynman is correct, I should have been more careful.
Well, the calculation looks formally correct.
However, one must make sure that this very unphysical and singular source is at least formally fulfilling the continuity equation, which is an integrability condition for the Maxwell equations. If I understand right, what's calculated, it's a surface current in the ##yz## plane, i.e., the correct current density is
$$\vec{j}(t,\vec{r})=K(t) \delta(x),$$
where ##(x,y,z)## are the usual Cartesian coordinates for the position vector ##\vec{r}##
Since thus
$$\vec{\nabla} \cdot \vec{j}=0,$$
the tacid assumption that the charge density
$$\rho=0$$
is consistent with the continuity equation.
Supposed there's no mistake in the lengthy calculation, everything looks fine (formally), since they simply use the retarded Green's function for the d'Alembertian for the four-potential in the Lorenz gauge. It's of course a highly idealized academic solution of the Maxwell equations, never realizable fully in nature.
Some more caveats concerning the possible choices for ##K## are given in the above linked pdf too!
Thank you vanhees71. I appreciate your response.
Why do you call this "radiation"?
It's radiative in the transient state. In the long-time limit, of course you get the static field for the stationary situation.
It is very interesting that the long-time limit includes a uniform electric field as well as the magnetic field. The Poynting vector is nonzero at all points in these fields, which indicates a flux of field energy away from the current sheet. This energy flux must be associated with the work required to maintain the current in the sheet. That is, an external agent must input energy to the system to maintain the steady current, and this input energy is balanced by the flux of field energy away from the sheet.
Does the energy all come back again if the current stops? This is surely the test for radiation or not.
No, I don't think so. Feynman discusses suddenly stopping the current at some time. The energy that has been radiated up to that time just keeps propagating outward from the sheet. http://www.feynmanlectures.caltech.edu/II_18.html (section 4)
  • · Replies 50 ·
  • · Replies 0 ·
