Radioactivity in quantum physics
Kairos
In a block of 1 kg of radioactive material that has reached its half-life, are the atoms in a superposed disintegrated/undecayed state (50-50), or are they all individually determined (50% disintegrated and 50% undecayed) before observation ?
This is Schrödinger's cat over again. In a 1 kg block, decoherence will be quite fast, and no individual atom left in a superposition for long.
Thank you, so it's a question of the number of atoms. In this case, could a single atom be the superposition of an infinite number of decay states following the exponential decay curve? For example, in the case of slow beta- radioactivity, the emission of an electron would be spread out over billions of years? and it would never end, asymptotically.
It is a question of an interaction with an environment. In this case, the other atoms act as the environment for a given atom, and it doesn't take long before those other atoms "observe" the decaying atom.
Theoretically, an isolated atom will have a unitary time evolution and always be in a superposition. Of course, so such system is possible in reality.
After the inevitable decoherence, there are two possibilities: either the atom is disintegrated and the story ends there, or it is not disintegrated. In the latter case, does it immediately re-enter a nondecayed/disintegrated superposition state?
This would mean that an unstable atom is constantly oscillating between coherence and decoherence?
  • Skeptical
After one half-life of a radioactive atom the probability is ##1/2## for the atom being non-decayed, and ##1/2## for being decayed. A probability ##1/2## for the two alternative possibilities (here: decayed/non-decayed) means that the two incompatible situations can now be considered equally possible at the instant of time meant by the prediction. These probabilities are valid for each radioactive atom in a bunch of ##N## radioactive isotopes of the same kind. In case of an observation on that bunch, half of the atoms are decayed and half of the atoms are non-decayed (if ##N>>>1##). That’s all what physics has to say, nothing more or less.
You are assuming that the quantum wave function is the physical state of a single atom. That is interpretation dependent. Not all QM interpretations treat the wave function that way. If you want to discuss how a particular interpretation works, that discussion belongs in a separate thread in the interpretations subforum.
As far as basic QM is concerned, @Lord Jestocost is correct: it gives you the probability of decay as a function of time. That's all you can say. You can't say anything about what the atom is or is not "actually doing". QM, as a model independent of interpretation, says nothing about that. It only tells you the probabilities of different possible measurement outcomes.
Yes, that's it. I'm looking for an interpretation of single atom decay in the same way as the Malus polarization experiment with single photons.
The purely probabilistic 1/2,1/2 description is similar to that of classical physics.
Due to this, I have moved this thread to the interpretations subforum.
Do we really need another Schroedinger's Cat variation?
No, I just wanted to know how radioactivity is viewed theoretically in orthodox quantum physics. DrClaude's post #4 is very instructive for me: decayed/undecayed superposition very quickly destroyed by the environment under ordinary conditions. In my old (classical) physics classes, radioactivity was presented as insensitive to the physical conditions of the environment; it plays at least a small role in this decoherence..
My additional question in post #5 following this answer may be far-fetched. Sorry about that.
See my https://www.arxiv.org/abs/2010.07575 Sec. 4.3 for an explanation why it looks as if the environment is irrelevant, despite the fact that there is no decay without environment.
Shouldn't quantum Zeno effect slow down the decay considerably in this case, compared to decays of single isolated atomes?
greypilgrim said:
Shouldn't quantum Zeno effect slow down the decay considerably in this case, compared to decays of single isolated atoms?
No, because the interaction with the environment isn't a preparation procedure for the original coherent superposition. "Continuously measured by the environment" is a sensible enough statement, but it relies on some fuzziness about what exactly is meant by "measurement", and it turns out that quantum zeno discussions are using the term in a different sense.
With QM.... At some point we always have to give up on natural language and turn to the math.
  • · Replies 37 ·
  • · Replies 31 ·
  • · Replies 20 ·
