Radius of curvature R of alpha particle beam
The discussion focuses on calculating the radius of curvature (R) for an alpha particle beam using the equation r = mv/qB. The user initially calculated a radius of 15.18e-4 m but realized this was incorrect due to using the electron charge (1.6e-19 C) instead of the correct charge for an alpha particle, which is +2 times the electron charge (3.2e-19 C). The confusion arose from not accounting for the alpha particle's charge when applying the formula. The correct approach emphasizes that the charge (q) used in the equation must reflect the specific particle being analyzed. Understanding the charge of the alpha particle is crucial for accurate calculations in magnetic field contexts.
asdf12312
r=mv/qb
mv=sqrt(2*KE*m(alpha))
m(alpha)=6.64e-27 kg
i was just wondering how to get the answer (7.6e-4 m). i get path curving down, and do
r=sqrt(2*1e3eV*6.64e-27kg*1.6e-19J/eV)/(q*B)
=15.18e-4m
so to get the right answer i would have to divide this by 2..why is this?? i used the right equation but am I doing something wrong?
What did you use for the charge of the alpha particle?
charge of alpha particle is +2. so if its only alpha particle I have to divide by 2? if it was electron (-1) I would not need to divide by anything??
You didn't show what number you used for q. It should be in Coulombs. What is the charge in Coulombs of an alpha particle?
I'm guessing its +2 times charge of electron. q=1.6e-19C
Right. An alpha particle has a charge q of twice the magnitude of the charge of an electron.
But, the magnitude of the charge on an electron is 1.6 x 10-19 C.
So, if q is 2 times the magnitude of the charge on an electron, then q ≠ 1.6 x 10-19 C
What value did you use for q when you got the wrong result of 15.18 x 10-4 m?
I was using q=1.6e-19C for electron. I guess it should've been 3.2e-19C but I forgot to multiply by the +2 charge. thanks.
Good. When using r = mv/qB, q is the charge of the particle that is moving in the magnetic field.
13K
