Raising indices in curved space
bdforbes
In curved space, can I raise an index on a tensor that is being differentiated? Ie, is the following true?
g^{\mu\lambda}\partial^\nu(F_{\mu\nu})=\partial^\nu(F^\lambda_\nu)
Only if the metric tensor is independent of x_{\nu}.
This is troubling. I'm trying to obtain Maxwell's Equations from the Lagrangian, and since we have indices both up and down ie F^{\mu\nu}F_{\mu\nu}, varying with respect to \delta A_\lambda inevitably introduces metrics:
\delta F^{\mu\nu}=\partial^\mu g^{\nu\lambda}\delta A_\lambda - \partial^\nu g^{\mu\lambda}\delta A_\lambda
Integrating a term:
\int d^4x\sqrt{-g}(\delta F^{\mu\nu} \delta F_{\mu\nu})
= \int d^4x\sqrt{-g}\left[\partial^\mu(g^{\nu\lambda}\delta A_\lambda)F_{\mu\nu} - \partial^\nu(g^{\mu\lambda}\delta A_\lambda)F_{\mu\nu}\right]
= \int d^4x\sqrt{-g}(g^{\mu\lambda} \partial^\nu F_{\mu\nu} - g^{\nu\lambda} \partial^\mu F_{\mu\nu})\delta A_\lambda
And now I have these terms which are confusing me.
What happens if you vary
g_{\mu b}g_{\nu a}F^{ab}F^{\mu\nu}
instead ?
I will try that, but I suspect it is equivalent.
If I had used covariant derivatives the whole time, there would be no problem. But here
http://en.wikipedia.org/wiki/Maxwell's_equations_in_curved_spacetime#Summary
it states that the extra terms introduced by using covariant derivatives would cancel out. So maybe my original method is fine.
Of course, I was stupid to overlook look this fact:
\delta F^{\mu\nu} F_{\mu\nu}=\delta F_{\mu\nu} F^{\mu\nu}
This may interest you.
"Maxwell’s Equations In a Gravitational Field" by Andrew E. Blechman
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
