RAM program for computing n^n in O(log n) time
  • Context:
  • Thread starter Thread starter mathmari
    Program Ram
15 replies · 4K views
mathmari
MHB
Hey! :o
Write a RAM program of uniform-cost time complexity $O(\log n)$ to compute $n^n$.Prove that your program is correct.
(Under the uniform cost criterion each RAM instruction requires one unit of time.)
So that the time complexity is $O(\log n)$ the size of the problem should get divided by $2$ each time, right?? (Wondering)
I have done the following:
Code:
Read n from input
result=n
i=⌊n/2⌋
j=⌊n/2⌋
while i>0
    result=result*result
    i=⌊i/2⌋
if j+j-n=0
    Write result to output
else
    result=result*n
Is this correct?? (Wondering)
The instructions of the RAM machine are the following:
LOAD a ; c(0) ← v(a), c(i) is the integer stored in register i (the contents of register i), v(a) is the value of operand a
(v(=i)=i, v(i)=c(i), v(*i)=c(c(i)) )
STORE i ; c(i) ← c(0)
STORE *i ; c(c(i)) ←c(0)
ADD a ; c(0) ← c(0)+v(a)
SUB a ; c(0) ← c(0)-v(a)
MULT a ; c(0) ← c(0) × v(a)
DIV a ; c(0) ← ⌊c(0)/v(a)⌋
READ i ; c(i) ← current input symbol
READ *i ; c(c(i)) ← current input symbol. The input tape head moves one square right in either case.
WRITE a ; v(a) is printed on the square of the output tape currently under the output tape head. Then the tape head is moved one square right.
JUMP b ; The location counter is set to the instruction labeled b.
JGTZ b ; The location counter is set to the instruction labeled b if c(0)>0; otherwise, the location counter is set to the next instruction.
JZERO b ; The location counter is set to the instruction labeled b if c(0)=0; otherwise, the location counter is set to the next instruction.
HALT ; Execution ceases.
The RAM program would be as followed:
Code:
READ 1
LOAD =n
STORE 2
LOAD =n
DIV =2
STORE 3
LOAD =n
DIV =2
STORE 4
while: LOAD 3
       JZERO endwhile
LOAD 2
MULT 2
STORE 2
LOAD 3
DIV =2
STORE 3
JUMP while
endwhile: LOAD 4
          ADD 4
          SUB =n
          JZERO res
LOAD 2
MULT =n
STORE 2
WRITE 2
res: WRITE 2
HALT
Code:
Read n from input
result=n
i=⌊n/2⌋
j=⌊n/2⌋
while i>0
    i=⌊i/2⌋
if j+j-n=0
else
    result=result*n
Hey! (Smile)
Let's see... suppose we pick n=6
\begin{array}{|c|c|c|}\hline
result & i & j \\
\hline
6 & 2 & 2 \\
6^2 & 1 & \\
6^3 & 0 & \\
6^3\cdot 6 & & \\
\hline\end{array}
Hmm... isn't that $6^4$ instead of $6^6$? (Thinking)
What does [m]LOAD =n[/m] do? (Wondering)Oh, and can you specify the list of instructions and what they do?
Perhaps in the opening post? (Thinking)
P.S. I can't edit my first post, that's why I write the instructions here.
That's okay. (Wink)
I have added the instruction set for you to your opening post.
And I've put them between spoiler tags so they don't take up so much space. (Bandit)
I like Serena said:
That's okay. (Wink)
Nice! (Yes)
result & i & j \\
\hline
6 & 2 & 2 \\
6^2 & 1 & \\
6^3 & 0 & \\
6^3\cdot 6 & & \\
\hline\end{array}
So, is it wrong to divide the step by $2$ ?? (Wondering)
Yes, I think so.
I think we should start with a step of 1 and double it.
And I also think we should track intermediate results.
We will need a smarter algorithm! (Thinking)
Perhaps we should take a look at an algorithm to implement $n^n$ in $O(\log n)$ time.
Code:
procedure pow(n, k)
  if k=0
    return 1
  result = pow(n, ⌊k/2⌋)
  result = result * result
  if k odd
    result = result * n
  return result
How does that look? (Wondering)
How could we compute pow(n,floor(k/2)) when there is no instruction to calculate the power of a number?? (Wondering)
Could we maybe compute it as followed?? (Wondering)
Code:
Read n from input
i=1
result=n*n
Result=n*n
while i<floor(n/2)
       Result=Result*result
       i=i+1
if n-2*i=0
       Write Result
else
       Result=Result*n
       Write Result
So we have to write it ourselves using multiplications and divisions.
That's what the algorithm I gave does. (Dull)
Code:
Read n from input
i=1
result=n*n
Result=n*n
while i<floor(n/2)
       i=i+1
if n-2*i=0
       Write Result
else
       Result=Result*n
       Write Result
What would the intermediate and final results of $6^6$ be? (Wondering)
I am confused with the algorithm pow(n,k) because it is a recursive function. Do we have to use a while loop?? Or can we write a recursive function in a RAM program??
Isn't it as followed?? (Wondering)
Read 6
i=1
result=6*6
Result=6*6
i<3 $\checkmark$
Result=6*6*6*6
i=2
i<3 $\checkmark$
Result=6*6*6*6*6*6
i=3
i<3 $\times$
6-2*3=0
Write 6*6*6*6*6*6
Yeah.
So the recursive function has to be "unrolled" somehow. (Worried)
The typical approaches are to either convert it into a while loop, or implement an engine that can handle recursive functions.
I suggest converting it into a while loop.
It still requires you to build up intermediate results in an array.
And, when you have them, work back to find the proper result. (Sweating)
Read 6
i=1
result=6*6
Result=6*6
i<3 $\checkmark$
Result=6*6*6*6
i=2
i<3 $\checkmark$
Result=6*6*6*6*6*6
i=3
i<3 $\times$
6-2*3=0
Write 6*6*6*6*6*6
Ah yes...
How about $n=1$? (Wondering)
I like Serena said:
Code:
procedure pow(n, k)
  if k=0
    return 1
  if k odd
    result = result * n
  return result
I tried to convert the recursive function pow(n,n) into a while loop... (Wait)
But I'm not sure if it correct... (Worried)
Code:
Read n from input
result=1
i=⌊n/2⌋
while i>0
     if i odd
        result=result*n
     i=⌊i/2⌋
Write result
I like Serena said:
Ah yes...
We have to take separately the case $n=1$, or not?? (Wondering)
Code:
Read n from input
if n=1 Write 1
i=1
result=n*n
Result=n*n
while i<floor(n/2)
       i=i+1
if n-2*i=0
       Write Result
else
       Result=Result*n
       Write Result
Code:
Read n from input
if n=1 Write 1
i=1
result=n*n
Result=n*n
while i<floor(n/2)
       i=i+1
if n-2*i=0
       Write Result
else
       Result=Result*n
       Write Result
It looks as if this algorithm will indeed give the right results.
However, you now have a while-loop that is executed floor(n/2) times.
Isn't that O(n)? (Worried)Perhaps we should take a look at the algorithm I gave earlier.
Code:
procedure pow(n, k)
  if k=0
    return 1
  if k odd
    result = result * n
  return result
Let's see what happens we apply the algorithm to $n=6$.
I will append the number of the recursion level, starting with 0.
Code:
pow(6,6)
  result0 = pow(6,3)
    result1 = pow(6,1)
      result2 = pow(6,0)
      result2 = 1
      result2 = result2 * result2 = 1
      result2 = result2 * n = 6
    result1 = 6
    result1 = result2 * result2 = 6 * 6
    result1 = result1 * n = 6 * 6 * 6
  result0 = 6 * 6 * 6
  result0 = result0 * result0 = 6 * 6 * 6 * 6 * 6 * 6
What we see, is that we recursively go down, first with k=6, then k=3, k=1, and finally k=0, and we effectively "remember" where we are.
Then we come back up and calculate $6^0, 6^1, 6^3, 6^6$.
Now suppose we create an array a[] that tracks where we are.
We will fill it with a[0] = 6, a[1] = 3, a[2] = 1, a[3] = 0.
Then we track the result, starting with $result=1$, and we work our way back from the end of the array.
Since a[2]=1 is odd, we multiply 1*1 by an extra 6 to get 6.
Since a[1]=3 is odd, we multiply 6*6 by an extra 6 to get $6^3$.
Since a[0]=6 is even, we finally get $6^3 \cdot 6^3 = 6^6$.
How would that look with a while-loop (or rather, 2 while-loops in succession)? (Wondering)
Yes... (Sweating)
Code:
procedure pow(n, k)
  if k=0
    return 1
  if k odd
    result = result * n
  return result
Code:
pow(6,6)
  result0 = pow(6,3)
    result1 = pow(6,1)
      result2 = pow(6,0)
      result2 = 1
    result1 = 6
  result0 = 6 * 6 * 6
I don't know how the recursion could be converted into two while-loops... (Wondering)
I thought that it could be for example as followed:
Code:
i=n;
result=1;
while i>0
   if i even then
   else
      result=result*result*n;
   i=⌊i/2⌋;
if n even
   result=result*result;
else
But this works only for $n=6$.
I got stuck right now... (Doh)
mathmari said:
Yes... (Sweating)
Code:
i=n;
result=1;
while i>0
   if i even then
   else
   i=⌊i/2⌋;
if n even
else
I would introduce an array $a[]$ to hold the powers of $n$.
And then I would do something like:
Code:
i=1
a[1] = n
while 2 * i <= n
  a[2 * i] = a[i] * a[i]
  i = 2 * i
remainder = n - i
result = a[i]
while remainder > 0
  if i <= remainder
    result = result * a[i]
    remainder = remainder - i
  i = i / 2
(Thinking)
