The discussion revolves around the potential application of a ramjet effect in a rocket-shaped drone designed for speed records, specifically addressing issues related to internal heat management and thrust generation at high speeds. Participants explore the implications of introducing air cooling through strategically placed holes and the aerodynamic considerations involved.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- Some participants suggest that introducing holes for air cooling could increase thrust due to hotter air exiting, likening it to a ramjet effect.
- Others argue that the ramjet concept is more complex and may not apply effectively at the drone's speed of 500 km/h, noting that ramjets typically require supersonic speeds to be efficient.
- Concerns are raised about the internal pressure generated by ram air at high speeds, with some participants questioning whether the pressure of 1.7 psi is relevant throughout the entire internal structure.
- Participants discuss the potential for internal circulation and the need for optimized ducting to minimize drag and maximize cooling efficiency.
- Some express skepticism about the actual thrust produced by the proposed cooling holes, suggesting it may be minimal and insufficient to overcome drag.
- There is a suggestion that external cooling methods, such as radiators or heatsinks, might be more effective than internal modifications.
Participants express a range of views, with no consensus on the effectiveness of the ramjet concept at the specified speed or the overall benefits of the proposed cooling modifications. Some agree on the need for cooling solutions, while others debate the practicality and efficiency of the suggested approaches.
Participants highlight limitations related to the assumptions about internal pressure, the complexity of aerodynamics, and the specific conditions under which the speed record attempt will occur. The discussion remains open-ended regarding the best methods for cooling and thrust generation.
This discussion may be of interest to those involved in drone design, aerodynamics, thermal management in electronics, and experimental propulsion systems.
