Rank of a Matrix - Physics Forum | Jennifer
  • Context: Graduate
  • Thread starter Thread starter Jennifer1990
    Matrix rank
The discussion centers on the properties of linear mappings and the rank of matrices, specifically addressing the inequalities rank(M o L) ≤ rank(M) and rank(M o L) ≤ rank(L). Participants clarify that the rank of a matrix is defined as the dimension of its range space, and they emphasize that the composition of mappings M and L must have compatible dimensions. The conversation also highlights the importance of understanding the relationship between the ranges of these mappings to prove the stated inequalities.
  • Understanding of linear mappings and their properties
  • Familiarity with the concept of matrix rank
  • Knowledge of vector spaces and their dimensions
  • Basic algebraic manipulation skills
  • Study the properties of linear transformations in detail
  • Learn about the rank-nullity theorem in linear algebra
  • Explore the implications of matrix multiplication on dimensions
  • Investigate the relationship between the rank of a matrix and its column space
Students of linear algebra, educators teaching matrix theory, and anyone interested in the mathematical foundations of linear mappings and their applications.
Jennifer1990
Hi,
My name is Jennifer and I'm new to Physics Forum. I was googling algebraic terms when I came across this site. It looks very helpful and I will greatly appreciate it if someone can help me answer this question:-
Let L : Rn --> Rm and M : Rm --> Rp be linear mappings.
a) Prore that rank( M o L) <= rank(M).
b) Prove that rank( M o L) <= rank(L).
Thank you~~
Jennifer
Jennifer1990 said:
Hi,
Thank you~~
Jennifer
The rank of a matrix is the dimension of its range space:
rank(M) = dim(range(M))
rank(M o L) = dim(range(M o L))
range(M) = the set of all vectors of the form Mx with x in Rm
range(M o L) = the set of all vectors of the form MLx with x in Rn
Compare the two and it should be obvious why (a) is true. Proving (b) is done similarly.
Hi jbunni,
I'm confused by your reply. We don't have specific values for m and n so I don't understand how we can prove a) is true :S
Jennifer1990 said:
Hi jbunni,
Try showing that range(M o L) is a subset of range(M), i.e., if y is in range(M o L) then y is also in range(M). To show this, write down what a typical element of range(M o L) looks like. It should be immediately apparent that it is also an element of range(M).
Then answer this: given that you know that range(M o L) is contained in range(M), what can you say about the dimensions of range(M o L) and range(M)?
Ohhhh I think I get it now...
M o L takes vectors in Rn, maps them to vectors in Rm and then takes those vectors and map them to vectors in Rp. It does not necessarily map a vector in Rn to each vector in Rm right? Therefore, M o L can be a subset of Rp. On the otherhand, M maps all vectors in Rm to Rp. Is this right?
That's exactly right. M o L means you are applying first L, then M. Notice that to form M o L, the dimensions of the spaces have to agree: if L maps Rn to Rs, and M maps Rt to Rp, then M o L can only be defined if s = t. In matrix terms, this means that you must have
# of columns of [L] = # of rows of [M]
where [L] and [M] are matrix representations of L and M, with respect to some bases of the appropriate spaces.
P.S. For future reference, the preferred place to ask homework questions is in the "Homework & Coursework Questions" section. The linear algebra stuff is typically asked in the "Calculus and Beyond" subsection.
Thanks! you were a big help. I'll ask future questions in the Homework & Coursework Questions. However, um, cud i ask you one more question?
Don't you mean # rows of [L] = # columns of [M]? :S...and how is this relevant to the answer other than telling u the dimensions of the matrix M o L which is pxn?
Yes, sorry, I got it reversed.
It's relevant only because sometimes it's easier to visualize what is happening with linear maps between (finite-dimensional) vector spaces if you consider what it means in terms of matrices, because many students already have some experience with matrices by the time they start learning about abstract vector spaces.
For example, the range of a matrix is the set of all linear combinations of its columns, so the dimension of the range (which is equal to the rank) is simply the number of linearly independent columns. This fact can help give you some concrete insight into why inequalities like the ones you are trying to prove are true, even though if possible the proofs themselves shouldn't depend on matrices.
Hi!
I was looking up a similar question also :)
Umm... I was wondering how you knew that M maps all vectors in Rm to Rp, and not just some of the vectors?
Also, for one of the rank properties I read about, it says that rank (ML) <= min(rank M, rank L). (I'm not sure if this is exactly relevant), but does this property imply that in this specific question, M maps ALL vectors in Rm to Rp?
9K
  • · Replies 44 ·
