Rankine Cycle Thermal Output Calculation for 1000 MWe
1 reply · 2K views
UnknownAnsem
The last part of my question reads:
Give the equations you would use to determine reactor thermal output if the plant is to produce 1000 MWe. All expressions for work and heat transfer rate should be expressed in terms of the appropriate mass flow rate ratios.
Efficiency = Wnet/Qh
I have been given turbine efficiency and pump efficiency. Also, assume I have found the enthalpy at each state point and was subsequently able to determine the net work and heat addition to the system. I feel like I need to determine the mass flow rate by dividing 1000 MWe by Wnet and then plug that value into the equation for Qh to get thermal output.
In general, posting only a part of a question is not a good way to attract users interested in providing help. The OP is in possession of all the facts, yet, for whatever reason, he has only provided a few bits of information with which to work. No one wants to play Twenty (or Forty) Questions; there's other things to do.
