Rate of Supernovae in the Milky Way Galaxy: Scientists' Best Estimate
The current best estimate for the rate of supernova explosions in the Milky Way Galaxy is approximately one every 50 years. This estimate is not directly represented in typical multiple-choice formats, where options include once a day, once a year, once every hundred years, and once every thousand years. The closest option to the 50-year estimate is once every hundred years. The last known supernova occurred in 1868, and the generally accepted rate for supernovae in an average galaxy is about one per century, influenced by factors such as redshift.
  • Understanding of supernova phenomena
  • Familiarity with astronomical terminology
  • Basic knowledge of logarithmic functions
  • Awareness of galaxy structures and classifications
  • Research the methods used to estimate supernova rates in galaxies
  • Explore the impact of redshift on astronomical observations
  • Learn about the historical context and significance of notable supernova events
  • Investigate the mathematical principles behind order-of-magnitude rounding
Astronomers, astrophysics students, educators in science, and anyone interested in the dynamics of supernovae and their implications in galactic studies.
Erenjaeger
Which option is closest to scientists' current best estimate for the rate at which a supernova explosions occur somewhere in the milky way galaxy?
a) once a day
b) once a year
c) once every hundred years
d) once every thousand years
From what I have found online, the current estimate is one every 50 years but the question on my practice exam doesn't offer that as an option. Anyone got any links or know anything to help me.
Thanks.
Space news on Phys.org
It asks you which option is closest to the current best estimate. Which of the four is closest to one every 50 years?
Well, if I wanted to quibble, I would say 50 years is only 49 years away from 1 year but 50 years away from 100. :wink:
The last known supernova in our galaxy was in 1868. (It was not visible because of dust, but the remnant has been found) The only one ever visible in M31 (the nearest large galaxy) was in 1885 (on the opening night of The Mikado). Given that, which answer looks the best to you?
Estimates like this work best by thinking about multiplicative differences instead.
For example, 50 years is fifty times the amount of time as 1 year, so those two numbers are very far apart.
Fifty years is only half of 100 years, though, so those two are quite close.
To do this a little bit more rigorously, you can use order-of-magnitude rounding. With this, numbers that are greater than \sqrt{10} (about 3.1) round up to 10, while numbers below this round down to 1. So in this case, 50 rounds up to 100.
The question is about rate per year. That's a ratio, not a number by itself. 50 is not one of the options, 1/50 is.
1/50 is a lot closer to 1/100 than is 1/1.
If one is considering multiplicative differences than it is irrelevant whether one is counting supernovae per year or years per supernova.
log(1/50) is closer to log(1/100) than it is to log(1) and for identical reasons, log(50) is closer to log(100) than to log(1).
  • · Replies 29 ·
9K
