Rates of Change Sliding Ladder Application
In summary, the problem involves a 5m ladder sliding down a wall at a rate of 0.5m per second. The goal is to find the rate at which the bottom of the ladder is moving away from the wall when it is 3m from the wall. To solve this, we need to relate the distance from the wall to the bottom of the ladder and the rate of change of this distance to the distance from the wall to the top of the ladder and the rate of change of this distance. We can do this by using the Pythagorean Theorem and differentiating the equation with respect to time. The resulting equation can then be used to find the desired rate of change.
Dirac
"a 5m ladder is placed against a wall. the top of the ladder is sliding down the wall at 0.5m per second. at what rate is the bottom of the ladder moving away from the wall when the bottom of the ladder is 3m from the wall. ? "
Dirac.
Dirac.
let x(t), y(t) be the distance respectively from the wall and floor.
1) relate x and y
2) differentiate the relationship to relate x' and y'
3) find write y(t) in terms of t then find x(t),x'(t),y'(t)
4) use x(ti)=3 to find x'(ti)
1) relate x and y
Could you please do a step-by-step solution
Dirac.
Dirac.
No.
so the ladder, a piece of floor and a piece of wall form a right triangle.
where the legs are x,y and the hypotenus is 5 can you write an equation relating these quantities?
lurflurf said:
No.
Yes, ok but what is x(t)
Dirac: TRY! If you can't get it show us what you have done and we'll give suggestions. The important thing is that you try yourself.
In a simpler way, if the ladder is moving down at a rate of 0.5m/s which is 5m above the ground, the ladder is slidding at the same time, so what you need to do is find the time it takes for the ladder to fall using v=dx/dt or v=x/t and then using the same equation use that elapsed time with the bottom of the ladder that is 3m away from the wall. does this make sense?
Yes, I can do it, but I get two solutions for t from
(x^2)=5t-0.25(t^2)
Dirac.
x is the distance from the bottom of the ladder to the wall measured along a line along the floor that is perpendicular to the wall.
y is the distance from the top of the ladder to the floor measured along a line along the wall that is perpendicular to the floor
also I am assuming the wall is perpendicular to the floor
thus we have a right triangle with legs x,y and hypotenus 5
I don't understand how you have a quadratic, this is a linear problem
I get from your values that the velocity of the sliding is 0.333m/s. But don't quote me!
I f you show me your working perhaps i can help
hhh79bigo
It is not linear
By Pythagoras'
(x^2)+(y^2)=(r^2)
y=5-0.5t
r=5
=>(x^2)=25-(25-5t+0.25(t^2))
=>(x^2)=5t-0.25(t^2)
Oh ok, done it now.
Dirac.
(x^2)=5t-0.25(t^2)
Dirac.
x and y should be positive
then there is only one solution
There is also an easier way
we know
x*x'+y*y'=0
so
x'=y*y'/x
we know y'=-.5 x=3 y=4 so x' is easy to find
(x^2)=5t-0.25(t^2)
Dirac.
And you STILL haven't shown us what you have done! Don't just give us your (wrong) answer. Show us how you got it.
In fact, your answer makes no sense. The problem does not even ASK you to find t! If you let x be the distance from the wall to the foot of the ladder, the problem asks you to find dx/dt.
Now do what lurflurf suggested to begin with: Draw a picture, look at the right triangle in the picture and write an equation relating the parts of the picture. That will be a "static" equation- your picture is kind of like a snapshot of the sliding ladder. To get a "dynamic" equation (a moving picture) differentiate the entire equation with respect to t (even though there is no t in the equation!)
For the same reason, the answer to hhh79bigo's question is "No, that makes no sense at all- you were not asked to find the time the ladder takes to fall to the floor."
For the same reason, the answer to hhh79bigo's question is "No, that makes no sense at all- you were not asked to find the time the ladder takes to fall to the floor."[/QUOTE]
Forgive me for being ignorant
I apologise I thought that the top of the ladder was 5m of the ground
hhh79bigo
1. What is the sliding ladder application used for?
The sliding ladder application is used to model and analyze the movement of a ladder as it slides down a wall. It helps determine the rate at which the ladder is moving and the angle at which it is leaning.
2. What is the equation for calculating the rate of change in the sliding ladder application?
The equation for calculating the rate of change in the sliding ladder application is velocity = (length of ladder) * (sin(angle of ladder)) * (rate of change of angle). This takes into account the length of the ladder, the angle at which it is leaning, and how quickly that angle is changing.
3. How does the weight of the ladder affect its rate of change?
The weight of the ladder does not directly affect its rate of change. However, a heavier ladder may require more force to push it down the wall, which could affect the rate of change. Additionally, the weight of the ladder may also affect its stability and angle, which could impact the rate of change.
4. Can the sliding ladder application be used in real-life situations?
Yes, the sliding ladder application can be applied in various real-life situations, such as when a ladder is being used to clean windows or to reach high areas for construction work. It can also be used in engineering and architectural design to ensure the stability and safety of structures.
5. How can the sliding ladder application be used to improve ladder safety?
The sliding ladder application can help identify the maximum safe angle at which a ladder can lean without tipping over. It can also determine the best angle for a ladder to be placed at for maximum stability. This information can be used to train individuals on proper ladder usage and improve ladder safety in various industries.
13K
